Page 1 of 3 123 LastLast
Results 1 to 15 of 36
Thread: C52 and E58 comparo
    wa
    Default C52 and E58 comparo
    some people have been curious about this for a whle and ive been in a position where i can document side by side the physical difference of these common 4ag transverse mounted gearboxes , most importantly being the weight so here it goes :
    boxes side by side, C52 on left E58 on right
    C52 front on
    E58 front on
    C52 top view
    E58 top view
    C52 weight
    E58 weight
    My Corolla ! - 4AGTE
    KP61 - 4AGE
    Default Re: C52 and E58 comparo
    Cool, nice work adsport!
    Do you know, of the top of your head, which gearboxes came standard in what cars?
    For example, AE101 Levin 4A-FE, S/T 4A-GE, and AE111 B/T 4A-GE Levin etc?
    Timbo
    Current rides...
    2) White RA25ST
    1) Red RA28LT (NOW WITH 1G )
    good stuff adz, though i would of thought after lugging both box's around the e58 would of been heavier. (maybe i'm just getting weak!) hahaaaa.
    Quote Originally Posted by feral4mr2
    I thought the exact same thing, I know a C52 is really easy to bench press into place, but I thought I could never do an E series..
    are they both dry weights?
    I notice a fair amount of oil around the E58.
    very good information none the less.
    wa
    Quote Originally Posted by timbosaurus
    Timbo
    the C52 there is from an AW11 (4age) and the E58 from AE92 (4agze)
    actually thats a very valid point , the E58 had been on its side for a long time and the oil that came out was very minimal. if anything i think the C52 will be full of oil ! the wet ground is 99% due to my garage being semi flooded just moments before due to a mass amount of rain during the day
    KP61 - 4AGE
    AE82 and AE92/3 SX / GTi models with the 4A-G come with C52
    whereas the E58 is from anything GZE powered... AW11 supercharged came mostly with auto boxes..
    My ae92 gze had a E52.
    They wouldn't be dry weights would they? I weighed my C52 and it came up around 25 kg.
    wa
    im thinking that the C52 is still full of oil , when it was removed (i didnt take it out) the input shafts werent removed but i do think its pretty close, 25kg seems pretty light ?
    the AW11 supercharged only came with E51 as a manual. autos are rare.
    KP61 - 4AGE
    doh! where is the delete post button?
    Quote Originally Posted by Vios-GT_07
    what the?
    as adz said.
    this is a long time coming for your repeated rubbish psuedo advice, you tend to dish out a non-stop stream of crap that is almost always wrong and talking out your arse just like this comment.
    neg rep for you.
    aw11 (sc units) came with e51 boxes, n/as came with c50 or c52 depending on age. (all in manual flavour) autos existed but are far far from common.
    ae92 gze vehicles early ones came with e52 and some of the later ones those with small port enignes tended to get e58 same as the ae101 gze
    Junior Member Conversion King deviant's Avatar
    wa
    Wow those weight differences are much less than I assumed!! Really puts an end to the conversation on if the weight saving is worth the effort of swapping gearboxes in an AW11 SC.
    Good work Adz!
    Quote Originally Posted by S2K
    Would a VTEC limiter be a helpful device?
    the shafts are also significnatly heavier as is the clutch/fly.
    if youve got an na there is no good reason to upgrade tot he e box. they dont make enough torque to break a c box, the ratios arnt as good for na and are no where near as nice to drive.. even a fresh one.
