Results 16 to 30 of 36
Thread: C52 and E58 comparo
    Default Re: C52 and E58 comparo
    quick question
    do the e52 and e58 have the same drive-shafts?
    the shafts are also significnatly heavier as is the clutch/fly.
    Quote Originally Posted by Vios-GT_07
    quick question
    one thread before you posted. look harder.. the shafts are significantly different
    Quote Originally Posted by Adsport
    the C52 there is from an AW11 (4age) and the E58 from AE92 (4agze)
    thats surprising, I would have thought all ae92 gzes would still be E51 or E52.
    Didn't SW20s have E58s? if not, what IS in an sw20t?
    the only thing ive seen an e51 in is an aw11 the e52 has the shifter on the other side but afaik is veyr siliar internally/same as the e51 in aw11's
    sw20 turbos had e153 which is similar internally to an e51 or e58 depending on year of manufacture.
    Aug 2006
    Are both boxes weighed equipped with LSD?
    as it looks like the E58 has one (5th picture), I was under the impression that not a lot of C52's had LSD
    My E52 was from a Ae92 trueno, Early Ae92 so it was AFM.
    wa
    Quote Originally Posted by blacktopspirit
    C52 is open centre. i doubt that it would alter it alot, not even half a kilo?
    My Corolla ! - 4AGTE
    KP61 - 4AGE
    Aug 2006
    I would think otherwise
    An LSD centre has a lot more metal in it than an open centre
    wa
    im sorry you'll need something more technical , we arent here to speculate we want to produce some facts
    KP61 - 4AGE
    Aug 2006
    I have no Factual back up, apart from lifting an LSD centre and it being heavy and lifting an open centre and it being not so heavy. if i had something to back me up i would post up info, but i don't, i was just bringing to light the fact one is LSD and one is open hoping someone can elaborate and thus making cents of the situation with some evidence.
    I could be wrong, i just want to know, that's all
    hrmm... well i guess i could weigh my lsd c52 tomorow to see what i come up with, (complete shafts are out though, can part and put stub axles back in required).
    my cousin has a small digital weigh bridge at the machinery wreckers he works at.
    sorry to get back a bit late on this.
    my c52 with lsd weighed in at 36kg.
    and with the shafts (complete), 50kg.
    after looking at adz weights again this seems right. his c52 was still full of oil, 2.6 liters they carry so theres the extra couple k's from his 38 kilo to my 36 kilo.
    Junior Member 1st year Apprentice Grippy's Avatar
    The c52 is a lightweight compared to the E51.
    I just ran out to the garage and weighed my E51lsd, that was pulled from a AW11 s/c half cut, dry the box itself weighs 61kg, with both shafts, 75kg, i knew it was a bruiser compared with the c52's and C56 ive put in the AW11 a few times.
    John, what sort of lsd is in the C52 box you have there?
    i'm not sure what breed it is mate, i bought it with a crashed import t-top na. all i know is it should go well in the vermin once i've sourced a light weight flywheel/clutch kit.
    can some one tell me the difference between lsd e58 and non lsd e58
