Results 46 to 50 of 50
Thread: 1G starts then dies, running out of ideas.... FIXED :) IT RUNS
  1. #46
    User Conversion King
    NWA
    Default Re: 1G starts then dies, running out of ideas, plz halp :(
    Quote Originally Posted by TheToyman75
    The cold start injector, if connected will supply enough fuel to get the engine to think about running.
    The question in my previous post still stands.
    Brett, its not the size difference thats important, its the high current verse low current thats a problem. If the ecu is configured to fire the wrong resistance injectors it won't be happy.
    yep this is definately something i would check.
    and also,
    what values have you got in your enrichements boxs? you might just need a bit more cold start enrichement??
    im mainly talking about "cranking enrich" and "coolant enrich"
    hello
  2. #47
    NWA
    in reference to rod's question,
    check the injector control (in wari) for the value of current (A) and whether the peak-hold box is checked
    hello
  3. #48
    TAS
    Quick post: yes, I'm using the right injectors. No, the setup doesn't use the stock cold start injector.
    I discovered using a noid light that the injectors are only pulsing once during crank, which is in line with the behavior - fuel starvation. Given that the ecu thinks that the injectors are pulsing, this indicates a problem with the ecu. I'm going to send it back for testing once I check some more wiring.
  4. #49
    NWA
    check some of those parameters i listed in the wari software,
    maybe your motor is cranking slower then the other 1g and not triggering start enrichment and the like
    hello
  5. #50
    TAS
    Default Re: 1G starts then dies, running out of ideas.... FIXED :) IT RUNS
    FIXED - IT RUNS!!!
    See here http://www.toymods.net/forums/showth...438#post709438
    Thanks everyone for their support
  1. Help Ideas anyone
    By Fidias in forum Tech and Conversions
    Last Post: 22-11-2007, 09:36 PM
  2. 4age starts, then stalls 1sec later
    By MRMOPARMAN in forum Tech and Conversions
    Last Post: 08-10-2007, 06:13 PM
  3. 4ag building. Good ideas vs Bad Ideas
    By DeftAnesthetik in forum Tech and Conversions
    Last Post: 08-08-2007, 02:19 PM
