Results 16 to 20 of 20
Thread: 3tgte ignitr. any interchangeable units.
    vic
    Default Re: 3tgte ignitr. any interchangeable units.
    Isnt the 3T leading and trailing spark ??? parallel connection of 2 igniters wont do this
    Dave
    my dizzy only has 2 wires so im guesing they are firing at the same time unless they are offset in the dizzy cap/rotor setting
    doh double post
    lilcrash, cambelt1,
    Yes twin spark, you would think leading and trailing spark but testing it myself and many other have also and found they both spark at the same time even the rotor phasing results in sparking at the same time.
    advantages of the original hardware, you can interface the knock control computer and I am sure splitting the signal has some electrical implications i.e. weaker signal due to load. However it ran ok for me and lilcrash has a similar setup working ok for him. I didn't run it for long so can't talk about the reliability of such a setup.
    By the way I don't use the original gear anymore I am using a megasquirt but still use the 5m/22re ignitor for a tacho signal.
    roger
    well ive run my bosch setup for ova 12 months and i have never had a problem
  1. fun times with 3tgte - parts/advice needed
    By ta22-3tgte in forum Tech and Conversions
    Last Post: 07-08-2007, 07:33 AM
  2. Ra23 -> Ra28 - Interchangeable Parts
    By twentyEight in forum Tech and Conversions
    Last Post: 24-10-2006, 12:56 AM
  3. 3tgte oil pressure
    By jeffro in forum Tech and Conversions
    Last Post: 15-07-2006, 06:03 PM
  4. 3tgte ECU and turbo
    By Diz44zy in forum Tech and Conversions
    Last Post: 27-06-2006, 04:16 PM
