Results 16 to 30 of 36
Thread: high hp 2jz spark plugs?
    Jun 2007
    Default Re: high hp 2jz spark plugs?
    See if you can use the X4 or X6 modules ( http://www.microtechefi.com/microtec...p?product_id=7 ) or just be done with it and go CDI.
    Btw, Iridium plugs use less energy to spark under the same conditions, so you have some leeway there as a cheap alternative using the current ignition system.
    Jan 2010
    Ive got BKR7s gapped to 0.6 and havent had any missfire issues. Stock motor, Vipec and gt42r yeilded 468rwkws (630hp)
    Stock NA JZA80
    jetpilot Automotive Encyclopaedia 1JZ.747's Avatar
    you have the x6 box dont you? mine has happily run 42psi before with an x6 with no issues with the bosch coils
    8.3 et PB 169 MPH PB
    yeh i got a x6 box
    i just solved my misfiring problem.!
    but now i wanna make sure im getting enough fuel pressure. anyone know what i should be running fuel psi for about 500hp
    perth
    as long as your afr's are in check your all good. fuel pressure, injector size and injection timing all play a part in carrying fuel for hp. usually 28-38psi at idle for fuel pressure.
    who are you getting to tune this thing?
    i have mine set at 45psi base pressure
    well def not unigroup. they completely fuked my car last time and had it for 4 month just for a simple install ecu and tune
    i was gonna go to matouks who i think own VL GOD or SAS
    anthony matouk owns vl god yes. good microtech tuner.
    alternativley, bring it up the freeway
    Or take it to croydon racing?
    Quote Originally Posted by 1JZ.747 View Post
    yeh he is a good microtech tuner,
    as for bringing it up the freeway i want to but ive sold my car trailer and tow car so ill just have to stick to taking it to matouks. but hes been great so far
    Feb 2007
    Timaru
    yes,
    45psi with no vacuum on the pressure regulator is normal fuel pressure on most cars,
    dont know why you would go lower than that? You would loose spray pattern.
    - KE70 Corolla Dx -
    - 500hp+ 7AGTE 20V turbo -
    - MRS/Hayabusa turbo **sold**
    Professional Amateur Grease Monkey sil80 1J's Avatar
    Feb 2008
    Quote Originally Posted by GU11TY View Post
    guys sorry to bring up an old thread bu im having this problem i think
    at 440rwhp my car is misfiring, at the moment im putting it down to fuel but cause also be spark
    im running bosch coils and leads and ngk plugs 0.7 at the moment on 2jz with microtech ignighter
    o was gonna go back to 0.6 to try that
    make sure your voltage is stable at high rpm, make sure its not dropping due to average alternator or wiring...
    Sil80 1JZ chasing 400rwkw
    Update: 4/5 the way there on 21 PSI, 350.3rwkw
    http://i112.photobucket.com/albums/n...L801copy-1.jpg
    Feb 2008
    yeh i got a x6 box
    sorry, didnt read on...
    what was your problem?
    wen the tuner changed my plugs the 2nd lead wasnt on 100%
    was on enough not to misfire but under alot of boost it would misfire.
    Feb 2008
    Cool, always a good feeling when its something silly
  1. 3T GTE - Wasted spark??
    Last Post: 11-04-2007, 08:34 PM
  2. What spark plugs for 2JZ with GT35 20psi
    By 2JZR31 in forum Tech and Conversions
    Last Post: 17-02-2007, 12:28 PM
  3. splifire spark plugs
    By joe90 in forum Tech and Conversions
    Last Post: 29-05-2006, 06:35 AM
