Ive got BKR7s gapped to 0.6 and havent had any missfire issues. Stock motor, Vipec and gt42r yeilded 468rwkws (630hp)
See if you can use the X4 or X6 modules ( http://www.microtechefi.com/microtec...p?product_id=7 ) or just be done with it and go CDI.
Btw, Iridium plugs use less energy to spark under the same conditions, so you have some leeway there as a cheap alternative using the current ignition system.
Stock NA JZA80
you have the x6 box dont you? mine has happily run 42psi before with an x6 with no issues with the bosch coils
8.3 et PB 169 MPH PB
yeh i got a x6 box
i just solved my misfiring problem.!
but now i wanna make sure im getting enough fuel pressure. anyone know what i should be running fuel psi for about 500hp
as long as your afr's are in check your all good. fuel pressure, injector size and injection timing all play a part in carrying fuel for hp. usually 28-38psi at idle for fuel pressure.
who are you getting to tune this thing?
i have mine set at 45psi base pressure
well def not unigroup. they completely fuked my car last time and had it for 4 month just for a simple install ecu and tune
i was gonna go to matouks who i think own VL GOD or SAS
anthony matouk owns vl god yes. good microtech tuner.
alternativley, bring it up the freeway
- KE70 Corolla Dx -
- 500hp+ 7AGTE 20V turbo -
- MRS/Hayabusa turbo **sold**
Sil80 1JZ chasing 400rwkw![]()
Update: 4/5 the way there on 21 PSI, 350.3rwkw
http://i112.photobucket.com/albums/n...L801copy-1.jpg
wen the tuner changed my plugs the 2nd lead wasnt on 100%
was on enough not to misfire but under alot of boost it would misfire.
