Results 1 to 15 of 29
Thread: How painful is it to change CV's on a FWD?
    Default How painful is it to change CV's on a FWD?
    Evening all,
    So, it seems my fine daily will be needing the CV's changed at some point in future. Having never touched anything FWD before (buying this car was a necessity.. not a choice) - just how hard is it to do yourself?
    Is it worth bothering, or is it cheap enough at a mechanic to just pay for it to be done?
    Bardin
    ed: By the way, CV is too short a term for searching, so if there is threads on this, by all means point me in the right direction
    The Supreme Backyard Mechanic
    Default Re: How painful is it to change CV's on a FWD?
    i think it stands for "continuous velocity"... or something like that..... or at least that's what comes to mind....
    Anyhow, simple as... what car?
    Normally involves undoing shaft nut, unbolting most arms/rods from bolt, pulling out the old shaft, put in new shaft, bolt everything back up....
    depending on car, may need to stop lube from pouring out of the shaft input.
    Rebuilding a CV shaft is a little more involved, but normally just entails the replacement of the outer and inner joints, which you can purchase in a kit that contains lube, the joints, and the boots and straps.
    If you choose to be lazy, i think it only takes an hour by a mechanic.
    Cheers.
    Tan.
    Constant velocity, yep... CV's are the actual joints, the rest is the shaft.. search for driveshaft etc and you should find more info
    As for how hard to replace them, how long is a piece of string?
    The type of car will come into play slightly, it's one of those jobs... extremely easy provided you have the correct tools and have done it before... otherwise so long as you're pretty handy with a spanner it shouldn't be too hard for a first timer
    Mechanics shouldn't charge a lot to change them, there shouldn't be more than an hours labour all up to replace both front driveshafts
    I am the sun
    Yeah, but who is going to make a thread about continous velocity joints
    Car.. a 92 honduhh civic. If its relatively easy, my finances at the moment mean that i will do it myself rather than be lazy. I was imagining needing to lift the engine and stupid shit like that
    The basic work involved is:
    crack the hub nut(s) and undo them - good breaker bar and a long jack handle or piece of pipe will likely be needed for leverage, as well as a large socket (toyotas are 30mm)
    undo the hub from either the lower control arm or the strut (depends on the suspension setup of the car)
    drain gearbox oil (you can reuse it if you drain it into a clean container)
    remove outer CV joint from hub
    pop cv joints out of gearbox with a sharp blow using a
    screwdriver/breakerbar/prybar/whatever fits in there best
    replacement is the opposite except you have to pry the cv inwards with something (lever works best)
    I am the sun
    Zub Zub Domestic Engineer Gavatron's Avatar
    Adelaide, SA
    Honda's aren't too bad IIRC. Remember to drain the trans fluid or you will probably have some coming out the axle holes. And be careful of the driveshaft seals when removing/inserting the splines.
    EDIT: Beaten
    I had one replaced in my corolla a few months back by a CV place at North Parramatta. I think it was around the $60-80 mark for them to remove and replace with a new one.
    I have done them before ie when removing the gearbox. It was easier for them to do it for me especially considering how much it cost and it only took him about 15 mins once it was up on the hoist.
    Today Im a Domestic Engineer Enchanter's Avatar
    Tas
    Just so you know, I had a torn CV boot replaced on my 95 Hondahh accord last week. It cost $102 total. It only involved 1 CV but included cleaning up the cv and regreasing it.
    Administrator Domestic Engineer mynameisrodney's Avatar
    $150 for both sides on my magna a few months ago.
    Adelaide, SA
    Are you planning on getting reco'd shafts? Or are you going to replace the CVs on the chafts yourself? There is more mucking around if you are going to replace the CVs themselves.
    how bad are they? making a clicking noise when turning? if so there farked, replacing the boot wont make anydifference,
    you can just buy the CV themselves, get a big brass hammer and put the shaft in the vice, and give the old CV a couple of good wacks till it comes off the spline,
    generally take about 1hrd to do each side, (thats being time generous)
    dont forget some GBOX oil either as you may lose a a bit of oil from thru diff.
    Blake
    Id suggest getting someone to do it. Under $200 for one side on my corolla. AE82.
    I was going to have a go at it but with no hoist and plenty of grease was getting thrown around everywhere i just payed someone to do it.
    One side or both? Can be done in one day by a shop but you could take a few days.
    Nov 2007
    go and get new driveshafts put in. most of them are exchange so don't cost a lot.
    can take 1 to 2 hours to replace both shafts. let the experts do the cv joints, I do and I am a mechanic. as for cv boots we have a device that stretches the boot over the cv joint saving a lot of time.
    I'll do some ringing around and price them up i guess before making a decision. It is clicking when turning, originally only when up my steep ass driveway but now on most corners, so i'm talking more than just the boot. Sounds to me like its only the passenger side.
    Thanks for all the help gents
    Ok, reco or new?
    Called 2 places, one said $140 exchange fitted for reco, the other said $180 exchange fitted, new.
    Its my shitty daily, is the extra money worth it? Or will they be just as good?
  1. wanting to change title name?
    By De@No in forum Toymods Car Club Membership and Feedback
    Last Post: 14-06-2007, 02:46 PM
  2. T series rear end diff centre change guide (warning, pics!)
    Last Post: 31-05-2007, 12:57 AM
