Results 1 to 15 of 20
Thread: W58 gearbox, cant find reverse.
    Feb 2008
    Default W58 gearbox, cant find reverse.
    I've got a w58 gearbox here and I cant seem to work out how to get it in reverse. It's got some weird setup where you push it and it's on the left side instead of it normally being straght under 5th gear.
    I can get it into 1st, 2nd, 3rd, 4th and 5th gear without any problems.
    Any ideas?
    Default Re: W58 gearbox, cant find reverse.
    Silly thought but you don't have the gear stick in backwards by any chance?
    Quote Originally Posted by Com_VC
    Certainly not a W58 then...
    ([][][]II--LT--II[][][])
    Built! not bought Grease Monkey SYC02T's Avatar
    Or it could be a W58 with a dodgie bearing, I had an old T50 do that to me. I just put up with it and thought of it as a safety measure. (not ideal tho).
    Don't know how different they are but I also found that when i accelerated and then backed off in third, the whole shifter would move a fair bit. Does yours do that also.
    If your not living on the edge,
    Your taking up too much space!!!
    Sure it isnt an early commodore 5 spd box?
    Nov 2007
    That's a borgie.
    Feb 2008
    it looks the same as a w58, has the steel sandwich plate in between the casings. Could possibily be hilux, not 100% sure what it came out of or how I can tell really. I bought the box as a conversion to use behind my commodore.
    not sure if the gear stick is backwards, but it shouldn't make a difference I dont think? On the gear knob it clearly shows that you have to push and turn it to the left to get to reverse.
    any ideas?
    Pics required. Could have an aftermarket reverse lockout installed.
    Who did you buy it from?
    Forum Sponsor Conversion King
    remove said gearknob and use it like a normal gearbox
    if its a W58 or pretty much any toyota gearbox it should be
    1 3 5
    Neutral
    2 4 R
    if its not like that and all the detent springs are in the correct position then i dont think its a W series.
    linden
    Feb 2008
    Cheers, looks like some clown fitted the wrong gear knob. All good now, got reverese
    Can you get shorter shifters for these? The one that came with it is massive. Or do people just cut them down?
    Thanks
    Junior Member Grease Monkey Maverick's Avatar
    N.S.W.
    lol thats gold
    Nov 2007
    Yep, there is a crowdin NZ making them, I bought one, $260 inc postage. Awesome. Fantastic build quality. Won't work on a borgie though
    Thanks
    yep, short shifters are available and generally pop up on ebay fairly cheap.
    while on the subject of clowns, who in there right mind looks at a gearknob and thinks it must be correct
    linden
    Junior Member Backyard Mechanic Hash_ra23's Avatar
    i look at mine every gearchange...its like a street directory for me
    1977 RA23 Celica -> 1ggte conversion [SOLD]
    MA70 Supra 1JZ 5speed [SOLD]
    Current: IS200 1JZ VVTI 6 speed
    get a GPS unit with a screen, then you wont have to look down
  1. w58 gearbox mount
    Last Post: 30-07-2008, 10:06 PM
