Results 16 to 30 of 40
Thread: 1JZ Not making boost?
    Xistant
    Guest
    Default Re: 1JZ Not making boost?
    Quote Originally Posted by JZA70 R
    from my experience ive never seen a CT12A sit there and spin freely at idle. As for hearing the turbo, i was referring to when it was at idle, obviously you hear any turbo when its working.
    I have a video of my 1JZ starting up and idleing with the turbo's clearly exposed and not moving at idle. These same turbos make 320rwhp @ 1.2 bar so no theres nothing wrong with them. The video is on youtube if you would like me to show you
    you learn something new now don't ya tod
    how long were your turbos sitting when you started it up?
    Can we stop editing posts and just make new ones. This is becoming confusing for me, as im refreshing every 5 mins to look for new posts as to why my car wont love me any more... And ppl keep editing and i dont see the edit. And it makes me cry hahaha
    Jase
    JZA023
    Quote Originally Posted by Xistant
    Sorry what have i learnt...?
    How long were the turbos sitting? do you mean was the motor hot or cold?
    JZA70|R / 12.45 @ 111 mph.
    Xistant
    Guest
    are these the 2nd pair of turbos you purchased bechase your ones were fubared?
    Im talking about the original ones one of which blew some smoke at idle but apart from that was fine? ...whats your point?
    Xistant
    Guest
    gee your a grumpy c*nt hey?
    you see when i changed my twins over the steelies spun slighty on idle, where as the ceramics didn't at all until a few months down the track i removed piping to clean up and check front blades that they also slighty moved @ idle.
    now lighten up ya fuck.
    Didnt leave a rag in the intercooler or pipes did you?
    I wish it was that easy. But nah
    Jase
    JZA023
    Forum Sponsor Conversion King
    every 1j ive worked on they have spun at idle, heck even my to4 spins at idle.
    maybe yours are slightly coked with burnt oil or something.
    jase, you know you need to put your foot down b4 the magical boost fairy comes along dont you?
    rip the D/S cooler pipe off the turbo outlet pipe and check if there is good airflow at a high idle say 2500rpm or so.
    if it does flow but makes no boost then check each one individualy to see if one is better than the other as 1 may have dropped an exhaust wheel.
    if 1 is rooted you can normally hear a strange swooshing noise as it tries to come on boost but due to one being fubared it just blows back thru the comp cover.
    linden
    The front one spins, pulled the front piping off and it spins, it also sounds insane
    It also blows air solidly at a generous rev. But at idle it just sort of hops around. Jumps a little, than stops, jumps a little and than stops... But there is no shaft play at all and spins quite smoothly, so i'd say its a relatively good cond turbo, and i would assume if they arent all like this, than it must just be coked oil or something...
    I didnt remove the rear cover though as its to hard to get to, but i can still pull the intake off after the turbo and feel for air through that one... So will do that tomorrow or saturday... Hopefully its an intake leak or maybe a fubared afm, is the 1jz a map sensored or AFM based engine? Also, if AFM where is it?
    Jase
    EDIT: Reason why i say AFM is cause, if the afm is fucked, would it not increase fuel accordingly cause it doesnt see all the air?
    JZA023
    It is a MAP engine, the later (VVTi) engines are MAF. Not sure where it actually measures the air though, most likely the manifold though.
    Well i must apologise if CT12A's do spin at idle. Mine must have issues, or maybe the motor was cold and the oil still thick?
    this is not a good thing at all - even an old-school turbo with bush-style bearing will spin at idle and quite freely.
    I would be checking oil supply, looking at the housing and blade edges for signs of contact and considering puttin aside cash for replacements or a big single upgrade.
    however, if you are only looking at a video of the compressor wheel not with your actual eyes, it may appear to be stationary at times, due to the slow shutter speed of (any) camera.
    Nah it was with the eyes, although, the motor has never really been run very long, so no doubt the oil was cold. Also, the idle would hunt between 900-1200, at 1200 it would spin, not freely, but slowly, and when it backed off to 900, it would stop again...
    But the turbos felt quite good when touching, they had no shaft play at all, and would turn, just not as easily as you make it sound like they should. Though i have never played with a non BB turbo, so i dont know if this is normal or not. Perhaps i'll get my mates t25 around. Its from an older sr20, and from memory they arent a BB turbo...
    Jase
    JZA023
    Quote Originally Posted by big_zop
    From what i've been told, it meassures pressure from the manifold...
    Jase
    JZA023
  1. Hybrid Boost Controller Installation
    By doobs in forum Tech and Conversions
    Last Post: 31-03-2007, 02:19 PM
  2. 2TG Turbo Upgrade - Advice/help please
    Last Post: 22-01-2007, 11:12 PM
  3. Best Boost Gauge Type?
    By BabyZ in forum Tech and Conversions
    Last Post: 06-12-2006, 06:57 PM
  4. Trying to wire up solenoid valve to boost controller?
    By trd-st162 in forum Tech and Conversions
    Last Post: 21-11-2006, 09:35 PM
  5. TA63 boost spike problem
    By Diz44zy in forum Tech and Conversions
    Last Post: 28-01-2006, 12:44 PM
