flywheel, bell housing, spiggot probably different, clutch would be same as a 1jz along with all other clutch components.
dear all,
anyone can help me to find out or give me precise answer about the R154 clutch components on 7MGTE and 1JZGTE?! I know the box itself is the same for both but how about what is inside the belt housing like (from engine toward gearbox):
1. flywheel - fit for both 7MGTE and 1JZGTE?!
2. pilot bearing
3. clutch disc
4. snap ring
5. clutch release bearing
6. plate washer
7. thrust cone
8. clutch release bearing hub
9. clutch release fork
10. clutch cover
11. plate washer
12. wave washer
13. snap ring
14. belt housing
thank you.
Originally Posted by chaserbuddy
spigot?! do you mean the pilot bearing?!![]()
7M-GTE and 1JZ-GTE flywheels are different. 7M-GTE is 6 bolt (1 Offset hole) vs 1JZ-GTE 8 bolt.
2. pilot bearing (The bearing that goes in the back of the crank, usually called the spigot bearing)
Same (6201 Series Bearing)
3. -> 13.
Same. The clutch items / parts inside the bellhousing (Except the flywheel) are the same.
14. bell housing
Different.
thanks mate...
really appreciated your help...
