Results 1 to 5 of 5
Thread: HeLP!!! R154 - 7MGTE vs 1JZGTE on A70 (urgently)
    sel
    Question HeLP!!! R154 - 7MGTE vs 1JZGTE on A70 (urgently)
    dear all,
    anyone can help me to find out or give me precise answer about the R154 clutch components on 7MGTE and 1JZGTE?! I know the box itself is the same for both but how about what is inside the belt housing like (from engine toward gearbox):
    1. flywheel - fit for both 7MGTE and 1JZGTE?!
    2. pilot bearing
    3. clutch disc
    4. snap ring
    5. clutch release bearing
    6. plate washer
    7. thrust cone
    8. clutch release bearing hub
    9. clutch release fork
    10. clutch cover
    11. plate washer
    12. wave washer
    13. snap ring
    14. belt housing
    thank you.
    ouT of oRder!!!
    CUBE needED!!!
    Junior Member Grease Monkey chaserbuddy's Avatar
    Feb 2008
    Default Re: HeLP!!! R154 - 7MGTE vs 1JZGTE on A70 (urgently)
    flywheel, bell housing, spiggot probably different, clutch would be same as a 1jz along with all other clutch components.
    sel
    Quote Originally Posted by chaserbuddy
    spigot?! do you mean the pilot bearing?!
    ouT of oRder!!!
    CUBE needED!!!
    7M-GTE and 1JZ-GTE flywheels are different. 7M-GTE is 6 bolt (1 Offset hole) vs 1JZ-GTE 8 bolt.
    2. pilot bearing (The bearing that goes in the back of the crank, usually called the spigot bearing)
    Same (6201 Series Bearing)
    3. -> 13.
    Same. The clutch items / parts inside the bellhousing (Except the flywheel) are the same.
    14. bell housing
    Different.
    sel
    thanks mate...
    really appreciated your help...
    ouT of oRder!!!
    CUBE needED!!!
  1. MZ20 - 7MGTE To 1JZGTE Conversion Pics (56K Warning)
    By Danners in forum Engine & Driveline Conversions
    Last Post: 07-05-2008, 10:02 AM
  2. 1jzgte ra28.. How hard to use r154 as apposed to w58?
    By 77GZE in forum Engine & Driveline Conversions
    Last Post: 20-10-2007, 04:56 PM
  3. 1JZGTE (R154) clutch
    By andrewvibert in forum Tech and Conversions
    Last Post: 18-09-2007, 12:04 PM
