Results 16 to 26 of 26
Thread: Can 1JZ injectors be changed without removing the intake manifold?
    Default Re: Can 1JZ injectors be changed without removing the intake manifold?
    requiem what injector settings did you use for the jdm 2jzgte injectors? ...apparently if the settings are spot on your tune doesnt change with the power fc... was that the case for you?
    thanks for pics.
    JZA70|R / 12.45 @ 111 mph.
    No idea sorry i lost my tune ages ago and have really worked on the car since. A good place to start would the the injector info on the Datalogit file server. That might point you in the right direction.
    Malicious
    Junior Member Grease Monkey 3BarSuperstar's Avatar
    Nov 2007
    I think from memory you divide the old injector cc by the new cc and that will give you a percentage. Only works if the injector percentages haven't been changed to move the overall maps.
    Junior Member Grease Monkey EvilJack's Avatar
    State
    heres the forum link to big zop's post
    http://forums.toyotacressida.net/for...ad.php?t=44566
    pictues can also be seen here
    Quote Originally Posted by EvilJack
    Yeah what was your username and password for that forum again?
    Quote Originally Posted by big_zop
    Quote Originally Posted by JZA70 R
    IMPORTANT:!!! Remove the EFI fuse and crank car for a few seconds to lose the pressure in the fuel rail!!
    Dont think this would be sufficient?
    This won't drain the rail.
    (This technique only works with cold start injectors).
    Mos.
    when you pull the efi fuse that kills the pump, but are the injectors still active?
    Given that the Electronic Fuel Injection runs the injectors, what do you think pulling the EFI fuse does to the injectors?
    Mos.
    Xistant
    Guest
    Quote Originally Posted by Mos
    Mos.
    it makes trickery for tod haha
    Quote Originally Posted by Xistant
    If you cant contribute any useful information to this thread, or spell my name correctly (both which ive never seen you do, ever) please refrain from posting. thanks.
    Xistant
    Guest
    ok tod.
    * remove spark plug cover, remove front timing belt cover, remove intake cam cover. boo yah you have tight access *
    with never ending love from me
    Last Post: 12-07-2019, 05:11 PM
  2. 550cc US 2jz injectors into 1jz
    By Esselte in forum Tech and Conversions
    Last Post: 26-07-2007, 01:18 PM
  3. Aftermarket engine management and injectors
    By benjamin in forum Tech and Conversions
    Last Post: 14-05-2006, 01:05 PM
  4. 1jz vs 2jz heads
