Results 1 to 15 of 16
Thread: MX83 diff question
    Default MX83 diff question
    Hi all
    Yet another mx83 diff question.
    Does the LSD and open diff use the same housing?
    Is it just the internals that are different?
    Can LSD internals be swapped into an open housing??
    I know this is really the same question put in three different ways.
    Andrew.
    Default Re: MX83 diff question
    Should be the same housing although the axles are different between the open and lsd
    Jealousy is a curse
    p00 powar Grease Monkey Jin~Jah's Avatar
    housings are the same, I had the lsd and open diff next to each other, and there was no difference i could spot.
    As for the axle stubs, i'm not sure what the go is there.... important part is the pumpkin bolted straight in
    Quote Originally Posted by Jin~Jah
    Thanks.
    Somebody please give Jin Jah pos rep. It wont let me do it for some reason
    Jul 2007
    Quote Originally Posted by amichie
    Thanks.
    Done and done
    Montrose
    I put an LSD pumpkin in mine no worries...
    woah rep boost
    apparanlty i can now have a crapload more PM's too
    Thanks amichie and unclewal!
    CAE86 Grease Monkey ae95's Avatar
    planning on putting a grande lsd into my car
    will the lsd diff and housing bolt straight in or are the half shafts different?
    Bolts right in.
    May 2006
    I have a JZA80 Supra Torsen bolted into mine with the stub axles. The stub axles are slightly longer and have clips that retain in the centre. Same bearings, just used old crown wheel. Been running it for nearly 2 years now
    Quote Originally Posted by MX83GT
    That is amazing considering the JZA80 lsd is an A series and the MX83 is a G series
    I used JZA70 torsen lsd and axles in mine.
    Jealousy is a curse
    May 2006
    Talking Re: MX83 diff question
    I should clarify, I was told it was from a JZA80, but to make sure it would suit me, I made him measure the bearing seat diameter, centre width, crown wheel mounting hole spacing and outside diameter where the crown wheel bolted on. The measurements all matched the MX83 diff centre, so I bought it. He may not have actually known what it came from (ebay)
    Drop and Fit Grease Monkey mumblezzz's Avatar
    May have been JZX90/100. I'm using a JZA70 4.3 R&P in my car no problems.
    053Style
    well i have bolted in a grande lsd.
    just wondering if all the grandes came out with the same ratio? 3.9?
    the diff it replaced was a G292. i wanna work out if/how much my speedo will change
    Quote Originally Posted by ae95
    G292
    Crownwheel: 8 inches
    Ratio: 4.100:1
    Pinions: 2
    LSD Type: open (non LSD)
    Courtesy of Norbie
    http://www.norbie.net/ToyotaAxle/
    Rep him, and use that DB for great justice.
  1. RT 142 diff replacement.
    By Mr Multivalve in forum Tech and Conversions
    Last Post: 29-03-2007, 08:58 PM
  2. diff differences question :is300/is200/altezza
    By S.W.A.M.I. in forum Tech and Conversions
    Last Post: 24-09-2006, 11:03 PM
  3. ma61 diff in a ta22?
    By weapon x in forum Tech and Conversions
    Last Post: 19-04-2006, 11:25 PM
  4. Diff Question
    By mlaser in forum Tech and Conversions
    Last Post: 17-04-2006, 08:13 PM
