Results 16 to 24 of 24
Thread: 4agze + turbo = xx hp?
    working hard Backyard Mechanic
    Default Re: 4agze + turbo = xx hp?
    ive got this setup ... bigport 4agze minus charger , t28 s14 turbo strapped on with standard gze electrics running 7psi on stock actuator with big oil cooler .. Note !! with this setup it seems to have abit of lag up untill 2500 - 3000 rpm then it kicks in nice to redline car goes ok on 7 psi i cant imagine 12 when i get the a/f ratios tested. 1 good thing about running stock electrics is it runs perfect idle , cold start , and also runs very rich from factory which helps to not blow pistons.. It is fine to run it like this but like me your better off saving up for a standalone to fix the lag and get the best potential out of the car as the AFM and 365cc injector weigh it down. Also there is bugger all room to fit the afm in i needa to get a small odessey battery to make it fit
    Hope this helps
    http://img401.imageshack.us/img401/5559/019rp1.jpg
    http://img183.imageshack.us/img183/373/020vr4.jpg
    Reece
    ill let you know when i get my boost controller and get a power run ok mate
    Forum Sponsor Conversion King
    2500rpm=laggy? damn dude you should try driving a car that doesn't hit boost till 4000+rpm.
    i dont thingk its a lag issue, just a lack of torque from the 4a
    and yes once you pump 12psi or more in it will be alot more fun.
    linden
    perth
    life doesnt start till 20+psi
    hehe laggy 2500rpm some n/a cars are laggier than that
    My car is laggier than that.
    Beige.... The new Black!!!
    depends if it takes him 20 seconds to get to 2500rpm
    S.A
    thats not lag.... thats a major F**king problem
    hey it is quiet laggy takes awhile to get some power going, i blocked off the actuator for a few squirts makeing 15-16 psi is alot more like it!!!!
    Quote Originally Posted by Lambolica
    yeah, all the way to redline. NA = hardghey
    S.A
    Quote Originally Posted by reece12
    if its that laggy .....it could be retarded...... the timing that is
  1. Turbo Heat Shielding
    By MarioM in forum Tech and Conversions
    Last Post: 21-05-2007, 09:18 PM
  2. 7m-gte turbo leaking, need help...
    By shaun185 in forum Tech and Conversions
    Last Post: 05-01-2007, 07:58 PM
  3. 20V vs 4AGZE + Turbo
    By Pure-SX in forum Tech and Conversions
    Last Post: 20-07-2006, 05:12 PM
