Results 16 to 30 of 30
Thread: mx83/gx81 steering rack bushes
    Default Re: mx83/gx81 steering rack bushes
    Once you look at everything carefully you'll see how easy is it.
    4 bolts and about an hours work.
    Remember the hydraulic hardlines are fairly long, and they are somewhat flexible, so 5mm in the rack is probably 0.02mm of flex at the other end of the hard line almost a meter away.
    And yes, they are really easy to do.
    Junior Member Grease Monkey Jayem's Avatar
    suomi
    cant see there being much movement in the rack when it has hydraulic hard lines bolted to it.
    Isn't Cressida steering rack like this?
    And aren't there normal flexiple lines between the rack and reservoir and pump?
    Appelsiini jaffaa!
    There is a hard line which is a high pressure line, and the lowpressure return which is a flexible line. They go to and from the res/pump. While the two hardlines you have pictured there are as is.
    That high pressure hard line is still a soft line in the middle though.
    Its not hard from one end to the other.
    Hm,mine is. And its cracked. Probably replaced when the dodgy bros did the wrecker engine on this one, means ill probably need a new rack.
    It can't be hard from one end to the other.
    The motor moves independently compared to the rack.
    If it was hard it would snap/crack with in months of being brand new, if not before.
    It should be hard from the rack to where it bolts to the chassis rail, and then soft for a bit, and finally a hard section just before the pump.
    Probably replaced when the dodgy bros did the wrecker engine on this one.
    BigWorm and Placenta?
    Nah, someone else before i bought the car. Lots of little things wrong, which is why i got the car so cheap.
    just spoke to yota, $27.50 for one, $31.50 for the other bush, less trade.
    something else to add to the list
    CAE86 Grease Monkey ae95's Avatar
    interesting
    i paid $75 for mine and the guy said it was trade price?
    which toyota branch did you call
    are the part numbers the same as what cruzida provided?
    ok i have just done this.
    pretty straight forward as cruzida stated, 4 bolts hold the bushes in. (2 per side)
    on my car i had to remove the steering damper which is just an oil or gas strut which attaches to the drivers side bracket. Not sure if the mx83 came with this damper?
    took me about 1.5hours all up
    Yeah, early model MX83s came with the damper, late models dont.
    wtf what did i do?
    Hahaha
  1. gz20 steering rack compared to mz20
    By VasH in forum Tech and Conversions
    Last Post: 04-01-2008, 03:53 PM
  2. AE86 "Cusco" quick steering racks??
    Last Post: 02-06-2007, 01:13 AM
  3. ra65 rack and pinion power steering rack
    By Intense in forum Tech and Conversions
    Last Post: 27-04-2007, 12:12 AM
  4. 162 Celica Steering Rack Help!!!!!!!!!!
    Last Post: 03-05-2006, 06:43 PM
