Results 1 to 12 of 12
Thread: JZX83 Injectors 3 and 5 Issue?
    Default JZX83 Injectors 3 and 5 Issue?
    Putting this problem up for MrDOHC....
    Engine Details:
    JZX83 conversion, no idea on the state of the wiring, Stock ECU, no SAFC etc
    Problem Details as reported to me over the phone:
    Phil (MrDOHC) seems to think that cyl 3 and 5 are dumping in fuel? He has unplugged the injectors to them, with no difference in how the engine runs, but smells much less fuely...?
    No ECU codes...
    Anyone know of a cause?
    My thoughts:
    Cyl 3 and Cyl 5 shouldn't be grouped to a single injector driver (to the ECU) in the stock wiring, so seeing as the cylinders that aren't paired with 3 and 5 are OK I'd be feeling that the injector wiring is OK, and the ECU drivers... I'd be looking for a spark problem, and would start with pulling the plugs...
    Again tho 3 & 5 don't have shared ignition drivers on the ECU or igniter...so maybe plugs or coils...
    Default Re: JZX83 Injectors 3 and 5 Issue?
    earthing of Igniter?
    User Conversion King
    NWA
    the igniters dont need to be earthed
    cold start injector leaking?
    hello
    1JZ don't have a CSI
    Update: Apparently he plugged the injectors back in and it was fine...go figure? Tho he reckons he has a zaust leak that makes it sound like a diesel
    Forum Sponsor Conversion King
    even though you say it was 3 and 5 you can accidentally put no2 and no3 injector plugs arse about, i had the same problem with a JZA70 ecu and it turned out to be leaking caps and 1 resistor.
    it was intermitent to begin with but got more regular as time went on.
    linden
    hi all, thanks for the input
    the car just started doing it while it was on the turbo timer at the servo, was pumping out white smoke big time, i think it was raw fuel.
    at smoko i put the injectors back on and it was all good, the exhaust leak went away after a few hundred meters of driving, i'd say it was just contracted steel etc.
    i used about 1/8 of a tank to go about 10k when the injectors were hooked up, and another 1/8th to go the next 15k, as the car was labouring with only 4 cylinders working.
    i'll keep u all updated if it happens again
    The boobs are back
    Aug 2006
    i hate to say it but i agree with linden
    +1 for caps
    Quote Originally Posted by Mr DOHC
    exact symptoms that IMA01J had, was the caps + a resistor in the ecu
    linden
    linden
    i am 100% sure thats what the issue is, thats what happened to a few other blokes on here as well as my mate, its running ok now, had better start looking for a spare ecu to use now
    The boobs are back
    Tasmania
    I just had all the caps done in mine and got it back today. ALL were leaking and fortunately the tracks weren't totally destroyed. They guy who did it said he would be willing to do others if anyone is interested. Cost was $40 and I bought the caps which cost me $5.
    thats cheap as, the first one i sent away was over $500, normal price is about $150 but as stated if you can find somone smart enough *coughs* wilbo *coughs* you should be able to do it cheap as chips.
    linden
    Yeah man, if you want the caps in the ECU done just let me know!
  1. Which injectors for which 4AGE bigport ECU
    By Grega in forum Tech and Conversions
    Last Post: 04-08-2006, 07:49 PM
  2. Where to get BIG top-feed injectors?
    By Norbie in forum Tech and Conversions
    Last Post: 17-06-2006, 05:22 PM
  3. Aftermarket engine management and injectors
    By benjamin in forum Tech and Conversions
    Last Post: 14-05-2006, 02:05 PM
