Results 1 to 6 of 6
Thread: 2jzgtte no compression number six
    Exclamation 2jzgtte no compression number six
    Hey People its been a while, i am currently looking at buying a jza80 with a 2jzgtte in it the owner said his local mechanic has checked it out and doesnt have any compression in number six, is this a problem any one has seen before, the problem is the car is in sydney and i am in perth any one that has seen this problem let us know
    at the end of the day for no compression your cooling at what
    lifters jamming holding the valve open,
    hole in the piston, bent valve but since a 2jz is a non interference motor i cant really see it
    burnt valve,
    it has nil comp so you wont be looking at rings
    let us know if any ideas
    or a blown head gasket
    cheers in advance
    Default Re: 2jzgtte no compression number six
    It could be any one of the above, you've got no way of knowing without a physical inspection. It's certainly not a common problem with JZ engines though.
    Cleveland QLD
    Loose valve seat. Happened to me on my L/Cruiser.
    Forum Sponsor Conversion King
    Dec 2006
    if a 2j pops its "generally" due to 1 of 3 things
    1 poorly looked after
    2 badly tuned
    3 its had the arse thrashed out of it
    unless its got some expensive gear on it and your getting a bargain then i wouldn't bother as it may cost you more than modding a stocker to have it fixed "properly", but its up to you
    linden
    why not have it bore scoped?
    either way, if its cheap, its still cheap! plus you can buy shit loads of aftermarket parts off the shelf cheaply too if it need some work!
    well thats it i have only had 1jzgttes and have never heard or seen a problem, i was just curious if anyone has, im a mechanic who works at a machine shop anyway so fixing it isnt really a issue
    once again thanks in advance
  1. JZA70 and MA70 Specifications
    By twentyEight in forum Tech and Conversions
    Last Post: 18-12-2016, 10:18 AM
  2. 20v compression (compression test)
    By 2revup in forum Tech and Conversions
    Last Post: 20-03-2006, 05:06 PM
