Where do you start...
Depending on if the engine has any manifolding, brackets on it, get a super charger. I have one at home with a small pulley on it that makes around 14psi of boost on my engine before i turboed it. You need an intercooler for this sort of boost tho. I ran this with a factory 1GGZE computer without any problems, and it went hard.... Although the auto box that was behind it didn't like the torque/power increase, as it used to make 15psi by 1500rpm
I wouldn't bother changing the cams... Probably not worth the hassle. I never did until I added my big cams (8.5mm lift, 230 odd duration)Cam gears will help if you can find some tho....
Simplicity wise, much easier to splash out on an ecu, therefore leave plenty of room for improvment in the future too.
If you want to go turbo, I may consider may consider parting my setup. If I have no luck selling the car complete, I may well choose to split it up. And it's setup to fit perfect in a Z10 too
That's all I can think of at the moment. I might add some more later.
