Results 16 to 25 of 25
Thread: Tailsfhat: 3 prong options...
    Default Re: Tailsfhat: 3 prong options...
    If you do not like the Commodore cv joint you could fit a flange off a 4runner A340H auto transmission and bolt on a Hilux uni joint
    Jealousy is a curse
    Tallahassee, FL USofA
    The rubber donuts/Metalastic couplings can take way more 'mis-alignment' than any drive/propeller shaft to IRS setup can give it, compared to what they take on the half-shaft of a Lotus Elan. Except fot the large diameter, I think you'll get 3 for 1 with them, taking care of misalignment, sliding spines and absorbing shock.
    http://www.truechoice.com/prodinfo.asp?number=METCPL
    The 12 segment ones will have a lot less complience/bungee effect and were used for a lot of half-shafts before CV's became available, cheap & popular in the 70's.
    The old Alfa & BMW donuts I've seen have lasted MUCH better then the rest of the car, while the Lotus didn't because it gets 10 times their misalignment.
    Forum Sponsor Conversion King
    the toyota ones have a spigot bearing type arrangement inside then and don't really have alot of give.
    if the measurements are accurate you can run without a CV or slipyoke setup but just for ease of use id put it in anyway.
    linden
    Junior Member Grease Monkey BMWTurbo's Avatar
    Jan 2007
    I run a slips arrangement on the nose of the Diff. BMW has this from factory though.
    I do use the rubber donut to take up some of the missalignment of the front peice however (2-peice shaft).
    BMW centre bearing is rubber rmounted and has slight give fowards and backwards.
    Hmm! Looking the EPC pic, something springs to mind... there is only one uni in the system! That means that the rubber connector on the gearbox flange must be designed to handle at least the misalignment that comes from the gearbox angle moving up and down.
    The other important detail that people are missing is that the slip joint in the above image gets LOCKED in place after installation of the tailshaft. It is only there are an assembly tool and does not take part in absorbing any sort of changes in length once locked. This means that you can use a fixed length tailshaft with donuts, it just means it's an absolute pain to install and you need to get the length exactly right the first time.
    Yeah, they do have a spigot arrangement, but that's to centre the shafts with respect to each other, rather than using the donut to centre the shafts. It's not there to prevent the joint from bending.
    If I was to do all this again - rather than modifying the gearbox to use a slip yoke - I'd use the 4runner A340H flange and use a flange type tailshaft (with or without the locking slip joint ).
    Mos.
    Something like this?
    This is for a V160 (4-bolt flange) but same idea.
    Quote Originally Posted by Mos
    Mos: Can you explain how the shaft gets locked in place?
    I was looking at one yesterday (that was out of a car, separated) and I couldn't see any method used to lock them...
    I've never touched one, but I read the section on it out of an SC400 factory manual. I was trying to find the supra manual to quote it but gave up.
    The large nut supposedly locks it. I might try to find a manual section for it ...
    mos.
    queensland
    Sorry to bring this up again, but im half way through an aristo conversion and the rubber donut wont fit under the car so it has to go. By the looks of it, if i source i hilux adapter, than will this just bolt up to the back of my gearbox, and i can use the smaller flange for something custom? Cheers.
    Quote Originally Posted by sick01
    Yes the hilux flange should bolt to the rear of the Aristo gearbox, and you can build ur new tailshaft so it bolts to this...like norbies pic above.
    You will need to trim / remove the spigot for the 3 Prong rubber piece from the end of the gearbox output shaft. Otherwise it will prevent the tailshaft flange from bolting up!
  1. gearbox options for engine conversion
    By lowlux69 in forum Engine & Driveline Conversions
    Last Post: 10-11-2007, 03:15 PM
  2. Ke20 Engine Options
    By apneaquatic in forum Tech and Conversions
    Last Post: 16-05-2007, 10:32 PM
  3. 1ggte flywheel options?
    By worldwalker in forum Tech and Conversions
    Last Post: 26-12-2006, 08:18 PM
  4. twin piston caliper options.
    By MR22ZZ in forum Tech and Conversions
    Last Post: 13-09-2006, 03:52 PM
  5. 2JZ damaged, other options?
    By jzk25 in forum Tech and Conversions
    Last Post: 11-07-2006, 05:47 PM
