You really want drain holes at the lowest possible point of water accumulation.... If you suspect the Factory internal coating won't hold out for much longer (ie enough for evaporation to do its job), then definitely put in a drain hole, but also be prepared to then coat it really well on both sides with some quality etch primer and a top coat, with possibly some clear on top just to be super safe.
Then just keep an eye on it and see how its holding out, especially if you don't haven't got good access from the inside to make sure you've done a good job of it.
