nope
ten char
Its a pain removing the thermostat housing each time to drain the coolant from the 1JZGTE block, is there a drain tap somewhere that i'm not seeing, as many other Toyota block's have?
nope
ten char
8.3 et PB 169 MPH PB
bugger
ten char
just pull the heater hose off, and flush it with water till it runs clear,....make sure the heater is on.,
blake
Thermo housing is easy, Long extension + 12mm ( me thinks) and go from underneath![]()
11.72 @ 116.7mph = Quickest Stock Turbo Jzz30 series SoarerAnd 1st into the 11's
WOOOT!!!
Still going good![]()
You forgot the last step: get wetOriginally Posted by Dieseltrain
Forgot to mention, ONce nuts are removed, then go back up top and remove the thermo housing from above![]()
WOOOT!!!
Try the drain plug in the attached pic.Originally Posted by 1JZ-Rolla
GSE20 IS250 - daily
Manny, i'd have to check, but that looks like the spot where my turbo oil feed comes from![]()
I don't have a better pic handy so I just used that pic of a 2jz-ge for reference.
No oil feed visible on that 2jz-ge block but you can see to the lower right where the oil feed would be tapped on the turbo blocks.
So I guess just rearward and upward of your rear oil feed location is where the drain plug is.
GSE20 IS250 - daily
Yes that's about where it is, near impossible to get to if you have the original twins and big dump pipes on though. Thermostat housing is the easier option.
