Results 61 to 74 of 74
Thread: MA61 wishbone IRS
  1. #61
    Jun 2008
    Default Re: MA61 wishbone IRS
    Hey, That is a very tidy mod!
    How dose the offset for the wheels go?
    Wish I thought of that before my effort....
    -A
  2. #62
    Nov 2007
    Looks like you've put in a fair bit of work, don't forget your camber correction, did you not consider fitting those alloy wishbones, still I can see you have saved doing the frikken shock towers.
    Next time I would make a tubular frame/brace to mount the tops of coilovers, workwise wouldn't make much difference tho.
    To correct track I should use 46mm off set.
    To thechuckster, when I'm finished with the sheets I was going to make some seat covers for you but I think everybody else would want some too.
  3. #63
    Jun 2008
    Yer, the strut towers look like a lot of work.
    I still haven’t decided what to do about the suspension,
    was thinking of cutting down the spring seats & making some kind of coilover bracket.
    The lovely ally wishbones belong to a friend, going on a custom rod.
    If ya ever in need of a spare diff, I have one of the MA70 ones floating around.
    It was my first choice for the upgrade, but had trouble tracking down the CV's.
    -A
  4. #64
    Nov 2007
    I thought I best put up some pics without rust.
  5. #65
    Dude that looks frackin' pro! Nice work
  6. #66
    TAS
    Quote Originally Posted by Crambo
    Is your fuel-filler door now round?
  7. #67
    Nov 2007
    Yeah, I did that for larger flares that won't have that cutout around the door, they are modified front flares.
    This is with the original rear end but with the new axle I will have to reshape them again to lower the arch and stretch them just a little wider and due to the difficulties of making them removable I may fibre glass them on.
  8. #68
    Junior Member Carport Converter ecko's Avatar
    May 2007
    tasmania
    you ever finish this crambo?
  9. #69
    Nov 2007
    The basics of it is finished, hand brake cable to set up and rear brakes to fit on.
    Been a little occupied with the front end of the car.
    IIRC front offset will be 28mm and rear, to tuck the wheels in, will be 46mm.
    The wheels on there are 23mm offset.
    I'm actually working down the back end ATM doing the exhaust at the diff.
  10. #70
    Sep 2009
    Thats alot of work at the rear. Well done!
    ZZT231 sent me here
  11. #71
    Supra since '86 Backyard Mechanic rsdeo's Avatar
    Burlington Ontario, Canada
    Great stuff. Really like what you did.
  12. #72
    Nov 2007
    Hey Steve, this is a bump for you.
  13. #73
    NICE VIBE Backyard Mechanic marvis's Avatar
    Aug 2008
    That's a fair amount of extra track.
    I'm curious to see how the arms sit when it's on the ground.
  14. #74
    Nov 2007
    This pic I have is on the wheel dolly but should suffice.
  1. ma61 front end upgrade writeup.
    By nb86 in forum Tech and Conversions
    Last Post: 22-07-2009, 10:24 PM
  2. Replies: 27
    Last Post: 09-01-2007, 01:56 PM
  3. MA61 – GH Sigma LCA Upgrade - Negative Camber + Extra Track - GUIDE
    Last Post: 06-12-2006, 11:56 PM
  4. Buying an MA61 (Calling all ma61 nuts)
    By Sam Red Rolla in forum Tech and Conversions
    Last Post: 17-10-2006, 05:19 AM
