Results 1 to 6 of 6
Thread: T50 gearbox problems
    Jun 2007
    victoria
    Default T50 gearbox problems
    just fitted new (second hand) gearbox and the output shaft is unable to be turned when the box is in neutral, it came in gear but i shifted it out into neuteal and now i cannot select any gears or run engine with clutch out
    help would be appreciated
    thanks
    Mad****** Grease Monkey FASTFOO's Avatar
    vic
    Default Re: T50 gearbox problems
    Some times when the gearbox is out of the car and stood up on the bell housing if it gets a bump one of the selectors can drop into gear leaving the stick in neutral position, so then you have 2 gears selected at the same time locking up the box.
    What you need to do is remove the extetion housing and put the 3 selector shafts in neutral and put it back together.
    Good luck its not to hard.
    MATT.
    Yep I had this happen with a W50, it's frustrating but not too hard to fix.
    Jun 2007
    victoria
    thanks alot for the help guys, just knocked the selectors into place with a screwdriver and now back on the road
    Who greased my Grease Monkey Baref00t's Avatar
    Apr 2007
    I just did a manual conversion from the autoglide to a T50 in my '22, and the speedo cable fitting is different so I can't plug it back in - I don't remember reading anyone else having this problem... am I a moron?
    Hmm... that's like saying "my X3 excel isn't homo, it's got a 4G63 in it!!" A decent motor doesn't make a car less homo. Sorry, just makes you a quick poof!!
    http://www.toymods.net/forums/showthread.php?t=22706
    vic
    Yep they are different
    just get a manuel speedo cable and all should be good.
    Regards
    MATT
  1. T50 gearbox questions
    By spanners05 in forum Tech and Conversions
    Last Post: 25-02-2007, 09:03 PM
  2. How-to: Converting an MR2 gearbox to FWD (SW20 to ST162)
    Last Post: 27-12-2006, 06:22 PM
  3. MX83 Cressida Gearbox Problems
    By johnnilicte in forum Tech and Conversions
    Last Post: 15-06-2006, 08:36 PM
  4. T50 gearbox issues? TA22 celica... need help?
    By weapon x in forum Tech and Conversions
    Last Post: 12-06-2006, 09:09 PM
