Results 16 to 20 of 20
Thread: AFM "trick" in reverse.... my idea
    Victoria, Mt Macedon
    Default Re: AFM "trick" in reverse.... my idea
    I'd start going through the basics:
    - Check ECU for error codes (remember to delete them first) and follow up any problems
    - Check wiring to and pinouts from the AFM
    Hen
    Aug 2007
    Manila
    Hen
    i did this months ago after i installed the engine. i tested a silvertop of my friend and mine runs better even. it runs fine just that i feel that it's mapping isnt that aggressive.
    Quote Originally Posted by oldeskewltoy
    I'd try to swap the guts of your current AFM into a larger shell. From memory, the MA6 Supras used an AFM, swap in your electronics and you are running a larger door.
    BTW... the AFM and clicks is a Pat Braden* myth.... It never really works... and in the three cases I've seen it used... ALL three dumped the AFM within 6 months!!!
    can you explain this some more about this myth?
    I'll add a bit. The standard AFM spring is wound quite tight (at least in my 4AGZE) and so I doupt there is much extra flap tension to be gain by tightening the spring further. The 3SGTE AFM seems to have less spring tension than the 4AG(Z)E.
    AB
    well after looking at it for a while I have not done any modification to the afm instead i've changed around the vacuum lines a little, put the dashpot back in and did some adjusting to the throttle stops and TPS..... now its running better, just filled my tank last night though so time will tell if fuel consumption has dropped.
    side note: I am the unfortunate victim of a cold snap, woke up this morning to -25 celsius..... brrrr. snow as well so im driving sideways for the next couple of days.
    Quote Originally Posted by merc-blue
    Cheap tools take all the fun out of working on a car.
    My Rebuild and Conversion.... '81 Tercel 3A -> 4A-GE 20 Valve - ON HOLD.
    BAD ASS 1986 MR2 - Finally Moving forward.
  1. Idea :adjustable rebound and compression on sway bars
    Last Post: 23-09-2007, 11:01 AM
  2. 4AGE wont start. No idea what to try next.
    By Granto in forum Tech and Conversions
    Last Post: 30-07-2007, 08:26 PM
  3. Urgent! -- Wiring for the 7MGTE AFM Plug (1UZ, 7MGE might be the same)
    Last Post: 31-03-2007, 08:00 AM
