Results 16 to 22 of 22
Thread: 1GGZE into RT132 help needed
    south austraila
    Default Re: 1GGZE into RT132 help needed
    Just checked the toyota EPC... (Electronic Parts Catalog)
    No ECT listing for the GX81 = No ECT..
    & now toyota part numbers :- GX81, Gen3, 1G-GZE..
    engine control computer, ECU. # 89661-22300, & 89661-22310.
    Shift lock control, # 85933-22010.
    cruise control, # 88240-22230. (the Green box above)
    shock absorber control, # 89243-22070, & 89243-22090.
    rear clearance warning, # 89340-22020, & 89340-22040.
    skid control ABS, # 89541-22010, &89541-22030.
    traction control, # 89631-22020, & 89631-22030.
    i hope this helps...
    in short NO ECT for a GX81
    As for the GS131, Gen3, 1G-GZE..
    ECU, # 89661-30330..
    ECT, # 89530-30491..
    So they have different numbers so the GX81's ECU may have the ECT built in...???
    Project: '82, GA61 XX
    Some parts of the jigsaw puzzle might just be starting to come together.
    I wonder whether the wiring diagram i'm using is right for my situation. (Bullfrog)
    I'll press on, but if anyone has a bellhousing for a 1G, let me know. Ultimately that probably will be the way to go!
    Thanks,
    Glen
    south austraila
    I had that wire diag' as well it's crap..
    i've got 3 or 4 different ones, i'll look tomorow for them...
    i had to redraw a few of them.. as was crap..
    you should have a :-
    I'll also look through the EPC for other controlers, & where to find in you cut..
    Forum Sponsor Conversion King
    Dec 2006
    Quote Originally Posted by Glenno52
    Thanks,
    Glen
    as in a manual bellhousing? i have 1 maybe 2 here to suit w5#
    linden
    linden
    PM me with price on bellhousing. What about flywheel??
    Back to the auto questions:
    I am now fairly sure that the GX81 ECU also contains the transmission controls...
    Now, with only the 'Bullfrog' wiring diagram to go on,i had wired the ECU SP2 pin to the wire i thought went directly to it on the transmission.
    But, i have since found that it took a diversion in the loom to somewhere else, and not directly to the transmission!
    I'm thinking it might have went to the Cruise Control (removed) first, and then makes its way back to the transmission.(maybe as a different color even)
    That means that i have never had the Speed Control connected, therefore the cause of my major problem.
    What do others think of this theory??
    Now the next problem.
    The Speed Control in the transmission has three wires!
    Does the magnetic pulse signal from here back to the ECU only use one wire?
    Could the other two wires have gone to elsewhere like the Cruise Control?
    How do i determine which wire to use to directly signal the ECU?
    Am i going crazy? (No, don't answer that!)
    Thanks,
    Glen.
    [IMG][/IMG]
    Here is my SP2.
    It has 3 Wires
    Part No is 89544-30010.
    I assume that i'm having trouble because the Cruise Control had something to do with this.
    I'm not using the cruise control, so maybe i need a different Speed Sensor.
    Is there one that simply sends a signal directly back to SP2 Pin in ECU??
    I am not getting any signal at SP2 Pin at ECU.
    I have checked the solenoids with 12v connected individually, and they are working.(Click)
    Help Please!!
    Glen.
  1. Doing it. 1GGZE into RT142 Rona stuff around
    By Mickp in forum Engine & Driveline Conversions
    Last Post: 20-05-2007, 10:43 PM
  2. BOV on a 1GGZE??
    By 1G-UNIT in forum Tech and Conversions
    Last Post: 16-05-2007, 12:26 PM
  3. 1GGZE not running properly... Advice appreciated.
    By mic* in forum Tech and Conversions
    Last Post: 23-03-2007, 11:57 PM
  4. 4AGZE to 4AGTE in AE86 Info needed
    Last Post: 17-06-2006, 12:15 PM
