Results 1 to 3 of 3
Thread: Is this how to connect a EBC to 1JZ
    I have a pet Backyard Mechanic Gibbon's Avatar
    Aug 2006
    Lightbulb Is this how to connect a EBC to 1JZ
    Hi
    I'm about to take delivery of a HKS EVC IV Boost Controller. I thought I would have a go at installing it myself.
    This is what I've worked out - is this right?
    Yellow - goes to wastegate
    Blue - goes to Turbo outlet
    Green - goes to an outlet that has boost / vacuum pressure
    This is to just double check that I have the wastegate right.
    There is a setting on the back of the unit "SW" or "PO" - SW is for single port, swing valve or internal type wastegate type. I have a internal wastegate - yes?
    Once it's installed - is there something that needs to be done to remove the OEM one?
    Thanks
    wget -r http://www.toymods.net | grep -i "1jz MA61"
    1 Result found:
    Gibbons MA61 + 1JZ
    At Work I'm A Grease Monkey Hibba's Avatar
    Default Re: Is this how to connect a EBC to 1JZ
    Yep the setup is right.
    Internal Wastegate yep.
    And so to speak there isnt a stock boost controler.
    MX83 Grande
    DirtyWan Skyline GX
    tasmania
    seems right to me
    do u have to tee bother the turbo pressure ports together? or can u plumb one to the controller and block the other as they would both be running the same pressure
    i'v never been able to find an answer
    sorry to jump in on the thread
  1. 1JZ vs 7M alternator useful info and pics
    By Ribfeast in forum Tech and Conversions
    Last Post: 22-06-2009, 04:10 PM
  2. 1jz and Haltech e6k
    Last Post: 10-10-2006, 04:25 AM
  3. 1jz vs 2jz heads
