Results 1 to 5 of 5
Thread: volts gauge going crazy**lights dimming etc
    Default volts gauge going crazy**lights dimming etc
    hey guys this aint on my toyota but still just wondering if you can help me
    as my daily car i got a v8 eb fairmont on lpg gas
    and ever since i bought it the volts gauge has alays been goin crazy. goin bak and forward from like 11 volts to like 14-15. jumpin every second, and as a result of this my headlights and interior lights always kinda flicker etc.
    the car has a new altenator, the battery is finem but why is this doing this. its kinda getting annoying. should i change the battery but im pretty sure its fine!!!
    Junior Member Grease Monkey 3BarSuperstar's Avatar
    Nov 2007
    Default Re: volts gauge going crazy**lights dimming etc
    i could be a battery but i'd check the wiring to the battery, alternator and the earths on the motor. See if the wiring is burnt at the alternator terminal. Vt commodores were bad for this.
    most likely the the reg, put the multimetre on the batt and see what she reading
    earths or cables.
    put a dedicated cable from alt to battery for both pos and neg
    My Missus is a Domestic Engineer BradW's Avatar
    I used to work at a ford dealer when these were new and the fix ford told us for this problem (which is a common one BTW) was to rewire the sense wire for the voltage reg straight to the battery terminal on the alternator. I think from memory the sense wire was white/ black but please double check this before rewiring.
    Brad
    Old Corollas never die...
    My KE30
  1. vacuum gauge on sidedrafts?
    By styler in forum Tech and Conversions
    Last Post: 17-07-2007, 09:04 PM
  2. Air Fuel Gauge Installation on 1JZ-GTE
    By Danners in forum Tech and Conversions
    Last Post: 07-05-2007, 10:33 AM
  3. Turorial : how to install a gauge in z20 soarer in aircon vents
    By GU11TY in forum Tech and Conversions
    Last Post: 03-07-2006, 08:35 PM
  4. Water temp gauge install
    Last Post: 21-02-2006, 10:45 PM
  5. Gauge repair 101 for 40 series Crowns
    By gianttomato in forum Tech and Conversions
    Last Post: 01-02-2006, 10:11 PM
