Results 16 to 30 of 34
Thread: 2TG oil pump types
    Junior Member Backyard Mechanic sleeektoy's Avatar
    Jan 2007
    Auckland
    Default Re: 2TG oil pump types
    Quote Originally Posted by Mr Revhead
    hmmmm
    im feeling glad i sold my 2tg....
    am having major issues getting bearings for a customer!
    seems ACLs listings is very wrong
    I just went to Appco (panmure) and found a very helpful person there that checked out all the listings and sorted all the bearings, rings, etc etc - this was about 3-4 years ago though.
    I did end up spending a fortune at toyota on the chains, tensioner, slippers, gasket sets, oil pump, water pump, mikuni carb rebuild kit + more - if only i knew a Mr Revhead back then
    _____________________________________________
    TA27 GT - How rare can you get!!!
    RA28 GTV daily driver
    New Zealand
    hehehe
    yeah seems most of the tenioner bits and gasket kits are still avail. and big ends
    but i cant get mains anywhere!
    ACLs listings are not correct..... totally different
    please, no more PMs!
    Junior Member Grease Monkey styler's Avatar
    Jun 2006
    3t and late 2t main bearings are the same main bearings as late 2tg.
    same size, thickness, oil hole location etc.
    check it out:
    http://www.toymods.net/forums/showth...light=bearings
    New Zealand
    nice
    but you say late.....
    i havnt found anything about a difference in earlier engines, is there?
    this car is about a 70-72
    Jun 2006
    yeah *something tells me* that the bearings are narrower on the early 2t's and 2tg's,
    the 2tg early ones being the 220 and 222 head models, wide bearings on late
    260, 261, 262 head models.
    3t's only came out years later and are all wide bearings.
    here you go:
    http://www.swmotorsport.com/index.ht...t=d132_02.html
    Carterton
    Quote Originally Posted by styler
    Correct.
    Main bearings got wider on 2T# engines made after 7611. For 2TG that means after engine number 2T-8108803 (i.e. during the 260 head model run).
    Toyota part numbers for standard size bearings:
    engines up to no. 2T-8108803: 11702-27012
    engines from no. 2T-8108804: 11702-88260
    Mike
    71 TA22
    My Car
    New Zealand
    hmmm ok
    so wear the hell do you get bearings from!!
    toyota no longer do them...
    i think i can get b/e from japan, but so far nothing on mains!
    Carterton
    Any engine shop worth its name should be able to source them.
    Mike
    71 TA22
    My Car
    New Zealand
    ah no....
    no one has any listings.... all the listings for 2TG bearings so far have been all wrong!
    my customer is a garage that does a lot of competion work, they are good engine builders that have been doing it for a while, all their suppliers have come up a blank too.
    nex tstep is to see about custom bearings
    Jun 2006
    yeah i know a lot of 2tg stuff isnt listed anymore or is listed incorrectly.
    if you have a late model 2tg, ie the 260 head upwards then all the 3t bearings are
    exactly the same, thats what i have used.
    i use the standard grade acl bearings listed as : 2T / 2TGUE / 3T / 13T
    bearings part no. : 5m1689
    these are the late model wider ones.
    acl bearing catalogue : (as their page numbers are wrong)
    13t and 2tg is pg 511
    2t and 3t is pg 547
    also brd racing in the US does calico special coated bearings.
    Carterton
    Try these guys in Japan:
    http://www.kameariengineworks.co.jp/
    Page 19 on their catalogue.
    Very nice gear. Not cheap. They now have some outlets in the USA.
    Must admit it is 8 years since I last got crankshaft bearings for my 2TG but I dont recall any dramas sourcing them aftermarket then.
    Mike
    71 TA22
    My Car
    Jan 2007
    Auckland
    I had a look at some old receipts and i think my ones came from:
    Johnson Piston Rings Ltd
    918 Great South Road, Auckland
    Phone: (09) 579-7219
    New Zealand
    thanks guys ill check it out
    8 years is a long time though!
    and this is an early engine.... its a genuine TE27!!
    Carterton
    Nice.
    88220 or 88222 head?
    Would be good to see some photo's.
    Mike
    71 TA22
    My Car
    New Zealand
    no idea.... im in wellington and its in hamilton
    but pics are coming... i told them no pics, no parts! lol
  1. Replies: 47
    Last Post: 23-10-2020, 07:38 PM
  2. TG engine info!
    By MitchE in forum Tech and Conversions
    Last Post: 30-07-2010, 06:27 PM
  3. Dry-sump construction
    By Billzilla in forum Tech and Conversions
    Last Post: 19-10-2007, 01:51 PM
  4. 2tgue & 3tgtue info
    By chippa07 in forum Tech and Conversions
    Last Post: 06-01-2007, 07:29 PM
  5. Replies: 1
