Results 1 to 5 of 5
Thread: Spark Plug Tube: Cant Get Out Need Help.
    Normally Aspirated Domestic Engineer RT104GT's Avatar
    Default Spark Plug Tube: Cant Get Out Need Help.
    I have a 2VZFE Head that is missing a spark plug tube.
    For those who do not know that is the metal tube between the cylinder head and the rocker cover that keeps the oila way from the plug and leads and inside.
    I need to get one out or get a new one.
    We tried putting a 17MM socket inside and squeezing a vice grip on but the tube wont budge.
    Today the engineer is going to try to heat the head and cool the tube and hope it comes out.
    It cant be pressed it has to be grabbed.
    I need to get one but I dont want to saw a head in half to do it.
    Any ideas?
    1968 RT40S Corona 1600S series II (restore in progress)
    1973 RT104-MQFG 012604 Corona GT JDM (Owned since 1976 242000 km)
    1989 ST185-BLMVZ-0007199 Celica GT4 JDM (unmolested classic 95000 km)
    2012 ZN-6 86GT (shed find 5000 km in 6 years)
    Default Re: Spark Plug Tube: Cant Get Out Need Help.
    ive got a factory workshop manual at home from another motor with same tubes, i remember reading something about pressing them in, ill see if it mentions getting them out tonight.
    Just a random idea here, but I wouldn't be surprised if they are fitted in a similar way to valve guides.
    ie the head is put into a hot tub and then the guides are easily fitted/removed.
    Junior Member Grease Monkey Jonny Rochester's Avatar
    Tasmania
    With the 3S-FE, the tube is screwed into the head of course and your method would have got it out by now. Looking at the EPC for the 2VZ-FE, the tube is not ment to be seperate from the head. You can not order a seperate tube!!!! Bad luck. It looks like the tube is ment to be stuck there good.
    But if you already have a tube off, surely you can see if its ment to be threaded or pressed.
    Altia ER34 GTT Domestic Engineer JetspeedCamry's Avatar
    As mentioned in my PM to you Steve, the tube is pressed in. It is extracted with a tube extractor, sorta like a pulley puller, but just inverse. The head MUST be heated to remove and install, or else it will not budge.
    Regards.
    Kind Regards,
    Kurt.
    1998 ER34 ニッサン スカイラインGT- T
  1. Wasted Sparks VS Sequential Spark
    Last Post: 07-01-2018, 11:19 PM
  2. Oil in spark plug chamber 3sfe
    By dundee230966 in forum Tech and Conversions
    Last Post: 09-04-2007, 11:46 PM
  3. 4AGE Spark Plug Cover
    By AE92 Rolla 4A-GTE in forum Tech and Conversions
    Last Post: 29-10-2006, 05:13 PM
  4. How to remove spark plug tubes?
    By JetspeedCamry in forum Tech and Conversions
    Last Post: 05-09-2006, 05:39 PM
  5. Spark Plug Question
    Last Post: 22-05-2006, 07:09 PM
