Results 1 to 11 of 11
Thread: How to remove spark plug tubes?
    Altia ER34 GTT Domestic Engineer JetspeedCamry's Avatar
    Default How to remove spark plug tubes?
    Hey guys/gals,
    Just wondering how you remove the long spark plug tubes in the heads? Is there a special tool i have to buy (if so where do i buy it) or is there a technique which has worked for someone. The use of multigrips is futile, just slips around on the tube, there quite tight!.
    Thanks!
    Kind Regards,
    Kurt.
    1998 ER34 ニッサン スカイラインGT- T
    Toymods Club Member #302 Backyard Mechanic hi-ace's Avatar
    Default Re: How to remove spark plug tubes?
    Ok I had to remove the plug tubes from a 3S-F. The only way I managed to get them out was to drill a hole through them and use a rod to unscrew them.
    Ok this means that they can't be reused so buy your new ones before you do the job.
    Most important, make sure you put the spark plugs back in and do them up. as there will be metal shavings going down the tube. I used a vacuum cleaner to suck the shavings out before removing the spark plugs. allso make sure you collect ALL the shavings from around the outside of the tube to, you don't want it to get into the oil gallerys.
    This worked for me, but if anyone has a better idea by all means let us know.
    If it feels good "DO IT" Unless it harms others.(or upsets the RTA)
    Enjoy what you have To Day,cause you can't take it with you.
    My old Hi-Ace
    Junior Member Grease Monkey Cruiser97_80's Avatar
    Tasmania
    I've never had any trouble removing them with a good set of locking pliers i.e. vice grips.
    1990 ST185 GT4 3SGTE
    1991 ST184 SX 3SGTE
    1991 SW20 GT 3SGTE
    1998 ST215 GTT 3SGTE
    2008 VDJ200 Sahara
    Quote Originally Posted by hi-ace
    problem is that the tubes sit through the rocker cover...................they would leak oil and fill up the tubes?, unless you were to fill holes......
    blake
    Tasmania
    IN 05 NT i think you missed this bit
    1991 ST184 SX 3SGTE
    1991 SW20 GT 3SGTE
    2008 VDJ200 Sahara
    Yeah the idea is to get new ones in there..but yea..gotta get these out first.
    The drill method seems light it may work, be make an absolute mess of them!...
    Do these sit in below the plugs? Meaning that, do i have to remove the spark plug to get them out?
    Kind Regards,
    Kurt.
    Tasmania
    no you can leave the plugs in there.
    Make sure when you put your new ones in, put some thread sealant on the thread that screws into the head. Or you tubes will fill up with oil
    1991 ST184 SX 3SGTE
    1991 SW20 GT 3SGTE
    2008 VDJ200 Sahara
    Hmm well i tried using slip joint pliers, but they just keep slipping off the tube...and if i squeeze high up, it crushes the tube in, and then slips off haha. So thats not working. I don't have a big enough pair of vice grips, might borrow some.... think this will work better than the slip pliers?
    I found a tool on the net designed for removing them, but its a tad expensive
    Kind Regards,
    Kurt.
    use 2 of the big nuts that screw onto it ontop of the rocker cover, put the first one on upside down all the way tight and then the 2nd one on the right way and tighten now use the bottom one to loosen the tubes.
    If this dosn't make sense i can take a couple of pics to show you.
    cheers Craig
    Quote Originally Posted by CraigD
    cheers Craig
    My tubes dont have threads on them..there just flat, plain tubes...like in the pic 1st post.
    Kind Regards,
    Kurt.
    Quote Originally Posted by JetspeedCamry
    oops my bad
    well i would say get a decent size vice grip and give that a go
    Last Post: 12-07-2019, 06:11 PM
  2. Wasted Sparks VS Sequential Spark
    Last Post: 08-01-2018, 12:19 AM
  3. Spark Plug Question
    Last Post: 22-05-2006, 08:09 PM
