Airflow meter's measure mass air flow, either directly (hot wire type) or via calculation (vane/flap type plus the inlet air temp. sensor or those stupid kahman vortex things that mitsubishi use). Any air that the turbo/supercharger pumps has to come thru the AFM and so (in theory) the location of the AFM wouldn't make any real difference in response to airflow change.Originally Posted by Z2TT
However, most AFM's do have their temp. sensor, or their inbuilt temp. compensation (hot wire type) as part of the airflow meter housing and so if you add an intercooler or fitted a better 1, then the ECU doesn't know that the air going into the engine is actually cooler than it would be in standard form.
Where I see a bennefit in AFM in the intercooler piping is when the AFM becomes (or already is: 4AGZE's) a flow restriction. That is, the airflow capacity of the AFM will increase with air from the turbo/SC being pushed thru it.
The ECU would also be reading actual inlet air temps after the intercooler, but that may or may not be a good thing, depending on the way it's set up from the factory.
