Results 16 to 30 of 38
Thread: 2JZGE in a manual JZA80 STOCK power figures??
    Toyota fanatic Grease Monkey Gttwinturbomk3's Avatar
    Jun 2007
    Dunedin
    Default Re: 2JZGE in a manual JZA80 STOCK power figures??
    Nathan
    Correction to be made on my behalf yes you are right the NA model is quite a lot lighter than the turbo one.
    But the turbo model is what i say above. I was just looking at it on Wikipedia and it weighs what i said for the turbo. And ONLY 1460 for the NA.
    how would you feel about being beaten by a bogan in a standard V6 vn commy?
    nah i wouldnt be happy either
    I drive a 5ME so I'm used to it
    My mate only has a 4 banger magna so he's used to it too and this would be a big step up for him
    Jan 2007
    My manual NA A80 weighed in at 1480 KG pretty well standard with spare and full tank.
    JZA80 Convert Backyard Mechanic
    Quote Originally Posted by Gttwinturbomk3
    No, it's not. 1999 brochure says 1510kgs for the RZ model, 1490kgs for the RZ-S, 1460kgs for the SZ-R and 1430/1440kgs for the SZ. I assume these to be unladen weights as it gives heavier weights for each model which I would image is fully loaded.
    http://www.mkiv.com/specifications/9...re/1999-31.jpg
    Since when is Wikipedia accurate?
    Wikipedia is often accurate, if people update it. The ~1500kg weight for the TT was quoting from a couple of people on this forum who'd actually had their cars weighed.
    Dunno if I've seen you car, sounds nice. First thing I'd do is remove the MTEU from it though so it's a moot point
    It really isn't useful comparing masses specified under different conditions....
    You might want to state exactly what you're quoting before engaging in a "factual" argument...
    Manufacturer's specified mass is always less than weighbridge results, and those are not always accurate anyway.
    In any case, a 2JZ-GE, whether making 120 or 150rwkw, isn't particularly fast in a JZA80, and while slightly faster in an MA61 is still not uberly impressive
    Mos.
    Penrith BC
    my jza80 1380kg
    DEAD STOCK wakefield park 1:17
    thats not slow
    the point is the jza80 HANDLES and can use every bt of the low power output to actually DRIVE well... which makes it quick. just not on paper
    ../delete/ban
    tech moderator
    Is that the rego weight or what it actually weighed in at Ed?
    Penrith BC
    compliance paper weight (which im told is actual weight off the boat)
    still havent weight it myself
    ../delete/ban
    tech moderator
    A guy I know got his JZA80 down to 1350kg (according to corner scales) but only after putting it on a fairly extreme weight-loss program, so methinks 1380 for a stocker is a little optimistic?
    Was his a TT or an NA? Remember Ed's had a W58 instead of a V160, A-series diff, no turbo hardware etc. Povo spec
    Penrith BC
    yup, complete povo spec
    no abs
    no airbags
    no cruise
    w58
    open A series
    small brakes
    16" wheels
    ../delete/ban
    tech moderator
    The car in question does have a turbo engine, 6-speed etc but it's WAY beyond povo spec. All interior removed (back seats, carpets, door trim etc), AC/heater etc removed, stereo gone, most of the wiring loom stripped out (you should have seen the pile of wires), he even went as far as making his own exhaust pipe out of stainless sheet because all off-the-shelf pipe had thick walls and was heavy.
    I'm not saying Ed's car couldn't get to the same level, just seems very light for a totally stock JZA80 with everything in it?
    or worse yet
    im pretty sure i'd win with my old 18rg in my celica
  1. The 1UZ Mods Thread
    By CoronaC in forum Tech and Conversions
    Last Post: 11-05-2014, 07:19 PM
  2. AE82 Manual ---> Power steering conversion ease
    By hemi twofifteen turbo in forum Tech and Conversions
    Last Post: 24-05-2006, 05:09 PM
  3. SmallPort vs Bigport HEAD 4AGZ/TE power figures
    By nick.parker in forum Tech and Conversions
    Last Post: 18-02-2006, 01:15 PM
