try:
http://www.toymods.net/forums/showthread.php?t=31445
for the water temp housing
good luck
fonz
Hey guys, going to convert Anna's 28 to EFI in a few weeks, just need to round up a few more parts, but before I do this can someone please answer a few questions?
I haven't been able to find an EFI thermostat housing, so the plan is to get a water temp sensor adapter like this
http://cgi.ebay.com.au/WATER-TEMP-SE...QQcmdZViewItem
I just need to know, is there only one sensor that won't have a home if I stick with the standard carby thermostat? and what size is the thread for the sensor? and also what diameter is the stock radiator hose?
I also need to get some EFI fuel hose, can anyone tell me what diameter the standard RA28 fuel lines are? and if they are anything like AE86 ones with a smaller return line?
Thanks heaps for any help and info!
-Whitchy-
try:
good luck
fonz
deepdishfactory
The 18R-GEU thermostat housing is a different shape to clear the inlet runners; it's not the sensors that are the problem. If you don't get the GEU housing you won't be able to fit the GEU inlet manifold.
Norbie!
www.norbie.net
Thanks Fonz! I keep seeing that ad, but never looked at it cause it didn't say GEU! Looks like it is just a standard RG one tho!![]()
I did find one thing in my searching about the thermostat fouling on the throttle body, but it also said you can grind down the housing a bit to clear it, so that was the plan until an EFI housing turned up!
Thanks for the info!
Cheers.
-Whitchy-
