Bumping this up, I have the same problem.. the other day I had both my front windows down, turned off the car and 30 min later when I tried to wind the windows up they didn't work. The windows, mirrors, sunroof and electric seat don't work now, so they must be on the same circuit.
I've checked all the fuses, which are ok... fiddled around with the plugs and wiring in the drivers door but everything looks ok and checks ok with the multimeter except there is no power.
The drivers window switch plug has 6 wires..
Code:
White/Black Power.. or negative??
Red Window Motor +/-
Green/Yellow Window Motor +/-
Blue Goes to passenger switch (could this be (+) power for both windows?)
Blue/Yellow Goes to passenger switch
Blue/Black Goes to passenger switch
The passenger window switch plug has 5 wires if I remember correct
Code:
Blue
Blue/Yellow
Blue/Black
I looked at the electric seat wiring colours and there was a white/black wire going to that also but on both the drivers window and the seat wiring the white/black wire is earthed.
Was anybody able to find a diagram or anything? It doesn't seem like the problem is in the door wiring, I checked the pins for the 2 door plugs near the fusebox and none of them had power.
