Results 1 to 15 of 26
Thread: 2JZ firing order
    Default 2JZ firing order
    OK, I've spent several hours this weekend trying to get my goddamn 2JZ started. It chugs and splutters while cranking so I definitely have fuel and spark, but it sounds for all the world like an engine with a couple of plug leads swapped.
    This leads me to suspect I screwed up the ignition coil wiring. It's a waste-spark setup and I grouped the coils 1-5, 3-4, 2-6. Is this correct?
    I'm pretty sure #1 is firing at about the right time, although my timing light is super dodgy so it's hard to tell. I'm hoping it will be a case of swapping a couple of plugs and it will fire up, I'm losing a lot of hair over this!
    Default Re: 2JZ firing order
    Firing order is: 1-5-3-6-2-4
    Wasted Spark:
    1-6, 5-2, 3-4
    wa
    beat me to it
    Farken! I might have known I'd get something arse-about.
    So, if I swap #5 and #6 it should all be sweet?
    Bzz, John is right
    Chees
    Forum Sponsor Backyard Mechanic Soarer21's Avatar
    That will get the batching right but not the sequence
    Refer to Wilbo's post again and change sequence to suit
    I'd rather have a bottle in front of me then a frontal lobotomy
    Ah, gotcha. Out with the soldering iron tonight!
    Sequencing has already been mentioned, but for reference purposes aftermarket computers generally number their injector and ignition outputs in firing order rather than cylinder order, in contrast to factory computers that number outputs in cylinder order. That is, output 1 is the 1st firing event, output 2 is the second firing event (regardless of which cylinder that happens to be), output 3 is the third firing event, etc.
    In your case it doesn't matter, because no1 (and no6) gets fired first, no5 (and no2) gets fired second, no3 (and no4) gets fired third, but if you were individually firing each cylinder then you would need to address sequencing (ie output1 -> no1, output2 -> no5, output3 -> no3, output4 -> no6, output5 -> no2, output6 -> no4, assuming 1-5-3-6-2-4 firing order).
    BTW exactly the same philosophy follows for injector outputs...
    Mos.
    Quote Originally Posted by Mos
    Ah, I'm pretty sure that's how I've got it wired up but I'll double-check tonight. Thanks Mos.
    Mos.
    I got reamed by that a while back, very annoying.
    OK so I swapped #5 and #6, this improved matters significantly but something is still not right. I'm thinking the grouping is right but the firing order is wrong, but I didn't get a chance to check it.
    Forum Sponsor Conversion King
    Dec 2006
    swap the coil triggers from coils 2-5 and 3-4. this should solve your problem and get your 2jznoshit running like a fat kid to a cake sale.
    Yep, already done that and things improved dramatically. It still doesn't quite want to start, but it's definitely close. I suspect I'm getting an erratic signal from the CAS, no doubt due to the temporary nature of the CAS wiring at the moment. I'm going to buy a decent timing light on the weekend and hopefully that will tell me what's going on.
    i've been reamed by the same "firing order" instead of cylinder order on aftermarket computers.... i felt so stupid.
    Get wilbo to bring over a CRO too... to make sure you ahve the CAS wiring correct.
    ...... butt scratcher?!
    Victory is mine! I ran all new shielded cable from both sensors all the way to the ECU and it fired up easily and ran reasonably well. Still a bit rough but I suspect the AFR's are way out of whack. Tomorrow I'm putting the cooling system back together and I'll have a closer look at that.
    I'm so glad I got this sorted, I was ready to torch the thing to the ground! Thanks for the help guys.
  1. 2jz Bottom End 1jz Head
    By P.I.M.P.I.N. Soarer in forum Engine & Driveline Conversions
    Last Post: 17-04-2013, 06:27 PM
  2. 2JZ Water Pump onto 1JZ
    Last Post: 28-10-2008, 11:33 PM
  3. Replies: 11
    Last Post: 22-01-2008, 06:29 AM
  4. 18RG Oil Filter and Firing Order
    By ganador in forum Tech and Conversions
    Last Post: 08-11-2006, 02:59 PM
  5. 7MGTE coil pack firing order?? quick
    By boxh34d in forum Tech and Conversions
    Last Post: 27-06-2006, 07:07 PM
