Results 1 to 12 of 12
Thread: 1ggte aftermarket coils/computer and c.a.s which leads go where???
    Default 1ggte aftermarket coils/computer and c.a.s which leads go where???
    sounds like its running on 4 cylinders, im out of ideas to find which leads go where?
    RA23 1JZ VVTi 373hp - SOLD
    12.4 @ 110mph
    THE EVOROLLA 262.9hp - SOLD
    Default Re: Firing order for 1ggte
    1-5-3-6-2-4 im pretty sure any one confirm
    I need confirmation on that! can anyone go to their car and check?
    12.4 @ 110mph
    Mad****** Grease Monkey FASTFOO's Avatar
    vic
    All Toyota straight 6's are 1-5-3-6-2-4
    100% that is what it is on a 1G
    Regards
    MATT.
    all sorted thanks guys
    12.4 @ 110mph
    livin on the edge as a Grease Monkey Snyper's Avatar
    south australia
    follow the distributor cap..
    Daily - Prado 90series
    Work - T908 620hp Cummins ISX
    Shed - 1975 TA22 2TG
    Quote Originally Posted by Snyper
    it runs a crank angle sensor with aftermarket coils + leads run on a motec, I had the leads marked but the ink came off.
    12.4 @ 110mph
    ok now ive got the thing driving it sounds like it only runs on 4 cylinders, on idle its hard to tell if its right or not because of the cams. Now as stated above i run aftermarket coils/computer and a crank angle sensor, is anyone able to tell me how to diagnose a problem like this? + to make it more difficult there is only 3 coils
    12.4 @ 110mph
    Forum Sponsor Conversion King
    Default Re: 1ggte aftermarket coils/computer and c.a.s which leads go where???
    output 1 to coil for 1-6, output 2 to coil for 2-5, output 3 to coil 3-4.
    make sure the coils and leads are grouped as above or you will have a miss (and probly run on 4 like yours)
    check leads first then trace the wires back to the ecu.
    diagrams can be found on the motec site.
    linden
    Raastler Grease Monkey
    Maybe you could use some mathematics to sort it out
    6 cyls, 6 leads
    1 2 3 4 5 6
    1 2 3 4 5 6
    6 5 4 3 2 1
    And so on.. but you would probably end up with more than 100 possibilities..
    problem sorted
    12.4 @ 110mph
    Quote Originally Posted by Matt-AE86
    6 cyls, 6 leads
    1 2 3 4 5 6
    1 2 3 4 5 6
    6 5 4 3 2 1
    WTF
    firing order is 1 5 3 6 2 4 why would you hook it up any other way?
  1. 18RG Oil Filter and Firing Order
    By ganador in forum Tech and Conversions
    Last Post: 08-11-2006, 01:59 PM
  2. 7MGTE coil pack firing order?? quick
    By boxh34d in forum Tech and Conversions
    Last Post: 27-06-2006, 06:07 PM
