Results 16 to 23 of 23
Thread: 4a question, running on 2 cyl, damaged valves???
    Default Re: 4a question, running on 2 cyl, damaged valves???
    valves etc acted fine...
    i mean, how did it feel as far as resistance to turning goes, when you went past TDC for each cylinder?
    any damage to piston tops? pistons 1 and 2 magically clean? or funny marks from where they are adjacent to each other?
    It will rattle as it will be detonating. I did a HG the same way - between two cylinders. It was gutless, sounded like a wrx, and had some severe knocking under load from ignition occuring through the hole in the HG.
    A compression test should let you know if the HG is blown.
    Quote Originally Posted by LeeRoy
    indeed, i've suffered the same symtoms. a quick compression test showed 2 cylinders (was 2 and 3 in my case) with the same low reading. new HG and away i went!
    Compression test results:
    CYL
    1 - 60
    2 - 62
    3 - 158
    4 - 156
    The head is now coming off....
    Quote Originally Posted by feral4mr2
    Mine was 2 and 3 also.
    Should also mention that the detonation got worse very quickly. It started out as a very small knock and within 2 minutes it was very loud. Luckily i was at the bottom of my street when it decided to give up the ghost.
    If you didnt have a comp tester and wanted to see if it was this then removing the plugs and having a look into the cylinders should show all the bits of busted HG sitting on them. Mine had blown about a 2cm long piece out of the HG which was found in the chambers upon head removal.
    Quote Originally Posted by JoJo
    CYL
    1 - 60
    2 - 62
    3 - 158
    4 - 156
    OUCH! Good luck man. Maybe you can get another 4ac for free, or a 4age upgrade.
    So what was found when the head came off? anything yet mate?
  1. 3tgte valves question
    Last Post: 14-12-2006, 01:14 PM
  2. 3SGTE question
    By Mr_X in forum Tech and Conversions
    Last Post: 04-04-2006, 01:28 PM
  3. 7MGE running temp
    By JesseCrown in forum Tech and Conversions
    Last Post: 17-03-2006, 05:59 PM
  4. Running in a motor. opinions?
    By Aust162 in forum Tech and Conversions
    Last Post: 27-02-2006, 08:19 PM
