Results 1 to 15 of 19
Thread: 4agte high or low mount ae86
    working hard Backyard Mechanic
    Default 4agte high or low mount ae86
    Hey guys i am in the process of converting my 4agze to turbo , i have purchased my t25g which will be going on the car , but now i am thinking which way i should go with the turbo manifold , high or low mount keep in mind i will be upgrading to a gt28rs later down the track.
    Which way did you guys find easy to do and more practical , low mount takes up more room while top mount look like shit with a small turbo but makes heaps of room
    Also pics of setups would be appreciated
    Default Re: 4agte high or low mount ae86
    I prefer top mount due to the unfortunate factory location of the oil filter, but if you convert to a remote filter then low mount is a possibility.
    This is mine.......
    Junior Member Backyard Mechanic gixer's Avatar
    I went top mount using the HKS cast manifold and a GT28RS turbocharger.....looks tuff!!
    S.A
    PICS /\/\/\
    FWIW : A low mount can be made to look tuff too, when done right
    Forum Sponsor Conversion King
    Quote Originally Posted by 30psi 4agte
    and you havn't put up a pic of yours, why, its possibly the toughest 4agte getting around.
    Yer i plan to go to a bigger turbo so i am about to buy a kelway manifold
    Im using a low mount but thats only due to the fact that i have an ebay manifold.
    Where are you getting the kelway ones from?
    Either way you do it, if you are going to mount it far out from the head like the one in the picture you'll definitely want to go about adding some bracing to it to stop it cracking.
    Raastler Grease Monkey
    From my experiences its best to have a top mount. To keep it away from oil cooler and starter motor. I had a few problems on the track drifting with low mount. Not fun.
    perth
    well this was a very first turbo manifold i had and still using it today.
    except the turbo is a little bigger now.
    hehe the blue covers didnt last too long...
    Jun 2006
    Quote Originally Posted by gixer
    ive got a HKS cast manifold too and was thinking a upgrade is a option,was there any stuffing around putting the gt on to the manifold?
    when does the car start taking off/ making boost? 2-2500rpm?
    who said you couldnt make a ae86 rear quarter outa bog,fibreglass and expanding foam!!
    GT28RS bolts straight onto HKS manifold as it's T25 turbine bolt pattern, I've got the .63 A/R turbine housing, it's actually on a 20v with billet chromoly rods and forged pistons, custom cast alloy plenum onto quads etc.
    Feb 2007
    Timaru
    I run a low mount as the turbo I run is quite large and heavy and I wanted the weight as low as possible.
    Matt
    - KE70 Corolla Dx -
    - 500hp+ 7AGTE 20V turbo -
    - MRS/Hayabusa turbo **sold**
    sir Grease Monkey
    tasmania
    every manifold i have made has been a top mount ,it just makes it easier to get at everything, the oil drain is just a bit harder to route but powerwise i don,t reckon it makes any difference. cheers bigwad
  1. 4AGZE to 4AGTE in AE86 Info needed
    Last Post: 17-06-2006, 11:15 AM
  2. side mount seats & ae86
    Last Post: 12-04-2006, 03:31 PM
  3. AE86 Axle upgrade needed...
    By irishtwincam in forum Tech and Conversions
    Last Post: 07-03-2006, 06:19 AM
