man that thing is gonna be laggy as fuck on a 1J![]()
pics of my to4z, I have booked in my car toget intercooling pipes, manifold, dump pipe and turbo polished next saturday. i will post up pics of that when its done![]()
Project Soarer II - Sold
Evo 5 - The silver fruitbox
As if!!!! its gonna be awsome
dont be such a spoil sport your just jelouse lol
dont say you werent warned![]()
It is all good i am well awear on how laggy it will be.Originally Posted by MR 1JZ
The is a sticker on the back of my car that says "boost lag is just a courtious head start"
Should be on full boost by 4-4500 and when i do some head work (stage 2 of my project)
It will bring that down abit![]()
of course it is hard to see in photos but the exhaust housing on my ta45s still looks bigger than this. Mine is a .9 rear but I am unsure of exact turbine wheel diameter. I have a 65mm compressor wheel (inducer) and it makes 0psi at 3000rpm and full boost at about 4200-4500rpm in 2nd and 3rd gear. Stock cams, TB, inlet plenum, trust exhaust manifold.
1st gear is phucked though. Diff gears and ecu in limp mode could have contributed to that. full boost at 5700rpm or so.
Also, cams will usually decrease off boost performance but then flow more air in the upper rev range so the power doesn't drop off at 6000odd rpm like it does stock (even with single turbo).
yeah i noticed this...mine starts to drop around 6700rpm...Originally Posted by chris davey
time for the 264's methinks
Mine is a .96 rear with a 65mm exhaust wheel and a 67mm comp wheel and a .7 arOriginally Posted by chris davey
What is a ta45?
O and what boost are you running?
I have a HKS ta45s. It is a unicorn turbo, noone knows anything about it! Is stopped production in 99 and was a little larger than a t04s but not as big as a t51s. AFAIK the t04s is quite similar to the t04r which is similar to to4z. Confusing hey![]()
Rated at 650hp. As I said, yet to make anywhere near that![]()
Only running at wastegate spring at the moment which is 15.4psi. Will be upped to 20psi or so depending on duty cycle of 550's.
pfft have a cryOriginally Posted by chris davey
my wastegate spring is 7psi and with the hose from the top of the gate to the inlet plenium DISCONNECTED it would only boost to 19psi lol
next time I go back with a 20psi spring and an extra 10psi via the bleeder![]()
yeah that has got to suck! 7psi spring for pussies
I am using a norgen valve to let additional pressure in to the top of the wastegate rather than bleeding off from the bottom. Same system as Sean uses with the supercrown. Supposably keeps it a bit more stable.
well to be honest I only really want to run 26-28 psi so I might go and get a 14 pound spring and then leave the hose disconnected so it will only run max boost of 27-28 psi
either that or fork out for an ebc...
jaycar ebc FTW!
I am happy with my setup. I only want one boost level really.
hey gav, car is looking good! heard its gettong closer n closer! any updates? ohh and was it you who did the r154 swap into jamies car?
Yeah god damn it Gav, its been ages since Ive heard from you!
Last I heard you and/or a mate were makin up a custom ex mani out of steam pipe or somethin. Did you get it done yet? PICS NEEDED!!!![]()
I used to eat alot of natural foods. That was until I learned that most people died of natural causes.
