Results 1 to 15 of 17
Thread: Torsen or not?????
    west australia
    Default Torsen or not?????
    My car is up on the stands at the mo getting a service.92 jza70 blmvz
    Is there any way of being able to tell if the the diff is a Torsen or weather its just the stock diff?
    I have been told by previous owner that it is, and then told by some one that the model that i have got did not come with one standard. Any help with this would be much appreciated. Cheers. Tim
    (yes i know fu@k all about cars..but learning)
    Default Re: Torsen or not?????
    The JZA70 came with a torsen LSD standard. But the way to confirm is to look at your build plate inside the engine bay. If the axle code ends with a 9, you have a torsen.
    west australia
    Tks Norbie i shall check it out.
    west australia
    Code is r154 g294. so no torsen for me. unless it has been changed. Right
    User Conversion King
    NWA
    could have been changed, but more likely its still got the 4pinion clutch type LSD in there (code G_ _4).
    i have had a G series 4pinion clutch type LSD beside a G series torsen type LSD and the clutch type requires a decent amount of effort to turn the axles against each other. but the torsen spins freely like a open centre
    hello
    Easy way to tell: Select a nice, open peice of bitumen. Select 1st gear. Dial up 5000+ RPM, wheel turned to full lock. Sidestep clutch. If it goes halfway around then tries to push straight, you've got a torsen. If it just pushes straight, you've got an open diff. If the car dissapears into clouds of smoke and spins around its axis, you've got an aftermarket LSD.
    Worked for me
    RM
    If I've got on full lock, the car would be quite happy to disappear into clouds of smoke, and I have a Torsen...
    Quote Originally Posted by brett_celicacoupe
    Actually the 4 means 4-pinion open centre... no LSD at all. I'm surprised a JZA70 came out like this - is it an actual JZA70 though, or another model with a 1JZ conversion?
    well the code indicates it came with an R154 which means it had to be at least an MA70 w 7MGTE and most of them came with LSD...
    but yes it is quite odd...
    Project Soarer II - Sold
    Evo 5 - The silver fruitbox
    NWA
    sorry i meant 5
    hello
    Junior Member Domestic Engineer urantia's Avatar
    I had a 7mgte/auto ma70 with an open diff stock. Was sure all turbo versions had the LSD.
    98 3rz-fe Hilux 4x4
    97 Hiace AWD Super Custom 1kz turbo diesel (sold)
    87 MA70 w/ 1JZ-GTE Manual Conversion GT (moss growing on roof deteriorating away but open to offers)
    HHeLiBeBCNOFNeNaMgAlSiPS Backyard Mechanic
    Quote Originally Posted by jzed ay
    Are you sure that 4 isn't another 9? Which would make sense if a real jza70.
    you know what I mean this electric stream
    and my tears in league with the
    wires and energy and my machine
    this is my beautiful dream
    New Zealand
    toyota use 2,3,4,5 for diff codes...
    2 = 2 pinion open
    3= 2 piniion lsd
    4= 4 pinnion open
    5= 4 pinion lsd.
    the exception is FWD which at some point used letters.
    a= open
    c= lsd
    Correct but incomplete; they also use 9 for torsen centres.
    This only applies up to the 80's though, from the early 90's they switched to a completely new coding system.
    west australia
    Defenatly factory 9/92 jza70. Some diff info from todd here if interested. I'll just have to put it to the test. Build plate sez open so i rekon the guy i bought it off is telling porkies.
  1. Clutch LSD => Torsen LSD
    Last Post: 21-10-2006, 02:14 PM
  2. What torsen center is this? (10 bolt)A or G series? Pics**
    By 07XTC in forum Tech and Conversions
    Last Post: 29-12-2005, 05:14 PM
  3. Torsen Diff Centres??
    By kuchie in forum Tech and Conversions
    Last Post: 03-12-2005, 09:33 AM
