That is great news man!! Very solid curve too!
'77 YAMAHA XT500 - Project
The Drivers' Vault
Real love is a xA65 - if you haven't owned one, don't worry, i'll love them for you
In case you all were wondering a history is in these 50 pages. Here is a summery of what it takes to make 400WHP
Engine:
87.5mm 8:1 JE pistons
Pauter x-beam 3tc rods
Fidanza flywheel
ARP main studs
ARP flywheel bolts
ARP head studs (machined head to make studs fit)
Moroso oil pan and windage tray
knife edge crankshaft
SI stainless steel valves
custom titanium retainers and valve springs from RD springs
Catcams 2tg camshafts w/coated lifters
Kameari adjustable cam gears
Kameari idler setup (no factory chain guides)
Kameari upper chain
BRD racing geardrive
Custom intake (made by me) and exhaust header
80mm Nissan Q45 throttle body
Haltech E6x sequential injection w/crank and custom cam trigger
ID2000 injectors (on E85)
Bosch 044 fuel pump
GTX3071r
ae-86 (levin) footwork
TE-71 w/1uzfe
Autronics SM4
Awesome result,
Iam also thinking of fitting the gearset to replace the lower timing chain.
Has anyone had or heard any horror storys about these kits failing .
Turbotoy, was that power figure on an engine dyno? or was it on a chassis dyno?
Chassis dyno.
TE-71 w/1uzfe
Autronics SM4
Turbotoy, Well Done!
Thanks for sharing the specs turbotoy! Very nicely played sir!
I had been going to ask as I knew there was a smattering throughout the 3TGTE thread but hard to put it all together.
It is on E85 right?
Aaannnnnd if you don't mind me asking what boost level???
Jason
E85 yes and 24psi.
TE-71 w/1uzfe
Autronics SM4
Specs on his web site just 3tc rods. Not sure why he took them out one of the best available!
TE-71 w/1uzfe
Autronics SM4
From memory, my mate was talking about the cross-sectional strength of the x-beam rods being a lot less than that of I-beam ones. He gave me a link ages ago that explained the math behind why I-beams are heaps stronger than the same sized H-beams and when inputting the dimensions of the x-beams, the I-beams still won out. Definitely no having a go at your rod choice, I was just interested in finding out your opinion on them.
As got the specs, any idea what they weigh? The website doesn't list the weight (and I'm assuming they weigh less than my I-beams due to their design).
Cheers.
