Results 1 to 15 of 20
Thread: bodyroll in hilux
    Default bodyroll in hilux
    Hey guys been doing some thinking on how to reduce body roll in my dual cab 2wd hilux, its like driving a scool bus.My noob question is would welding a steel brace between chassis rails at the back do any good? or any other suggestions? Im thinking along the lines of strut braces in cars although as its leaf sprung am unsure how to stiffen the rear up
    Thanks for any input
    Default Re: bodyroll in hilux
    dont confuse body stiffness with body roll.
    what size anti roll bars does it have? these are also known as stabiliser bars or sway bars, and resist body roll.
    read up on the basics of suspension, google the above and look around.
    www.vicdrift.com
    now targeting: targets
    formerly shinybluesteel
    buy a 4wd one and embrace the roll.
    we 4wders dont call it roll, its called flex
    new shocks would probably be a start if you do want to stop it
    haha well flex, roll, schoolbus its all the same, nah like the 2wd its undergoing heart surgery at the moment in the form of 1uzfe engine im suffering withdrawal
    ahhh, ur one of those types (dont worry, i drive a nissan patrol, im just bitter )
    well, im assuming your lowering it, and im going to assume you were planning on using lowering blocks?
    can i suggest taking it to a suspension shop and talk to them about setting your leaves properly and recomending i good shock for your purpose, which will erradicate alot of roll, and if u still want stiffer, then uprade swaybars etc.
    replacing all bushes can help too.
    swaybars should really be the last thing, not the first, its just a patchup
    i thought body roll in a 2WD ute was a design feature not a flaw?
    Junior Member Grease Monkey Casino Kid's Avatar
    yeah, you need the body roll to help get one wheel spining round corners
    1989 MX83 Cressida- stock 1JZGTE /king springs/jic's/17's/jzx81 front end.. 248.9rwhp
    1988 GX81 Chaser, stock..........
    2001 hilux-Street racer/Drifter/Track king/ Daily driver
    The bodyroll is great in my RN41! Fishtails like a mofo in the wet ...
    HD torsion bars, thicker swaybar, reset the leafs in the rear rather than using lowering blocks - should all help a little.
    At the end of the day it's still a commercial vehicle.
    haha thanks for your help guys, might go and see they guys at morses under car.
    I object to it being called a commercial just doesnt fit the bill, yes there are plans to lower it and go lsd so i will post some pics when its finished
    it might look like a car, but its built like a truck. make no mistake. it will, and until you throw alot of money at it, will always handle like a commercial vehicle. but you can get the best out of it. isnt that what its all about
    wa
    i have a set of koni adjustable shocks in mine and it handles a lot better
    PM esteban to get his flatmate's contact details - he has lowered his 2WD hilux and changed the carrying capacity so he could run low profile rims/rubber etc (and he got the changes engineered to make it mostly legal).
    i like the term "mostly legal" im unsure as to how far im going to go asthetically, as in my opinion something that is a sleeper is better than advertising whats under the bonnet. All go no show as oposed to all show no go. But in saying that i have my eye on some 5zigen rims that wud look good.
    Once you pop u cant stop
    Junior Member 1st year Apprentice P100_Ute's Avatar
    Quote Originally Posted by Pure_In_Sanity
    i got electric shocks in the rear of my RN41.. switch in the cab to work them.
    need to sort out all the switches... got oodles.. lots arent connected anymore.
    thermo fans n the like.
    the locker in the Diff and the 5.8Litres of gas guzzling power helps fry tyres
    no single peggers for me.
    got 16" AU Pursuities for it.. just need to fit them and lower it at the front.. the rear is pretty stiff atm..
    My Daily. ---> 1990 KF Laser.
    My Project. --> Ford Cortina chopped into a Ute sitting on a RN41 Hilux Chassis running a 351 Cleveland V8. Auto with a Locker in Diff.
  1. Hilux - BA Rotors - Nissan GT Calipers
    By infotechplus in forum Engine & Driveline Conversions
    Last Post: 20-02-2008, 08:27 PM
  2. Hilux Tow Bars and Wheels
    By Son of Toyoda in forum Tech and Conversions
    Last Post: 26-06-2007, 07:09 AM
  3. changing the gear ratio's in hilux diff.
    Last Post: 14-10-2006, 01:41 PM
  4. Alloy Trays on Hilux/ Cruiser/ Hilux 4 door
    By Robbos_Toyotas in forum Tech and Conversions
    Last Post: 02-03-2006, 07:54 PM
