making the rear of the car lower is actually worse for anti squat as the lower arms are then more parallel to the body but this can be fixed by lowering the arms at the diff end (otherwise known as traction brackets).
the way they have done it in that car will increase wear due to the housing not being squared up with the diff centre (or so it looks) but it still does the job.
idealy barrel splined axles would be the go and having the housing cut correctly would give you the best possible solution to what you want but bear in mind its an expensive procedure.
linden
