Results 1 to 15 of 17
Thread: Help! CT12A Removal - JZA70
    King of Cool. 1st year Apprentice
    Default Help! CT12A Removal - JZA70
    Hey guys I’ve just started removing my ct12a’s of my 1JZ because they are stuffed. I’ve already hit a wall! Here’s where I’m up to:
    How exactly does everyone get to the bolts that directly join the piping to the rear turbo? One is circled here, and the other one is along side and further back than the one pictured.
    I tried going underneath and above but I can’t squeeze a ratchet in there, nor a ring spanner. Help!
    Default Re: Help! CT12A Removal - JZA70
    Start by pulling off the heat shielding and the hoses above it. Ive got a feeling that you can get the rear turbo out without removing the inlet pipe.
    Quick Edit: Heres a top notch guide on how to remove them Click Here
    I'll have a shot of removing the piping around the inlet and taking the shield off.
    Thats the guide i'm going by since im very much new to this, the guide doesn't go into detail with the removal of the inlet pipes but the soarer engine bay seems to be a little less cluttered than my supra's so it may of been much easier for him.
    Forum Sponsor Conversion King
    Dec 2006
    no need to undo those 2 bolts your talkin bout but if you feel you must the easiest way is from underneath with the exhaust dropped.
    linden
    side note: those turbos are super fun times to remove with engine in
    TRB01J Backyard Mechanic jak's Avatar
    Jun 2007
    there is really no need to remove them.
    they dont really get in your road.
    but the shielding will, so remove that.
    hmmm, on the subject of ct12a removal, has anyone unbolted the manifolds from the head, and pulled the whole thing out?
    EDIT: does that sheild around the brake fluid thing unbolt from the bottom??
    Jak
    '77 RA28 Celica - Repairing Rust...
    '84 AE71 Daily Driver/Race Car
    '91 MX83 - Fastest Standard Turbo 1JZ Powered Vehicle In The World -
    10.74 @124 Mph
    http://www.youtube.com/watch?v=H2ido6yirZ8
    Junior Member Grease Monkey Yojimbo's Avatar
    Nov 2007
    Quote Originally Posted by jak
    Jak
    Yep,
    also taken the factory dump pipe off without removing turbos.
    SUPER FUN TIMES is an understatment!, but not impossible with a lot of patience and some lateral thinking (cheap disposable spanners that you dont mind modifying also helps).
    Jun 2007
    yeh we modify our spanners aswell. supercheap auto ftw.
    did you take the studs out?
    Jak
    10.74 @124 Mph
    Jak
    I've taken all the shields off which has gained me a tiny bit more room. I've just hit up bunnings for a bunch of 50c spanners to bend into various shapes. If that's still too hard im just going to remove everything else around it since there's probally no real need to remove it anyway.
    Nov 2007
    Jak
    Yeah back the studs out, and rotate the dump untill the rear bolts are exposed, undo and back them out too.
    Gangnam style Automotive Encyclopaedia beatle's Avatar
    Perth
    its easiest i found to drop the exhaust from the dumps and reaching up from underneath with a spanner, try and get one thats inbetween the length of a stubby and a sidchrome one
    Western Aus
    fucken nightmare.
    i swapped my dump out (tee-hee) with the turbos still bolted to the manifolds, had to wind the fuckwit studs out, took 5 spanners, bent in different shapes, and 1 special spanner i ground down in thickness to wind the studs themselves out.
    fun fucken times!
    worst
    job
    evar.
    AU
    Underneath 4tw... that is the easiest way to get into that spot (not sure easy is the right word though).
    Trust me, I removed my turbo's on and off 4 times several months ago (long story with memories im trying to repress). Actually in the end I kinda liked doing it?... wtf is with that LOL.
    Roll Ons? Carport Converter Endless's Avatar
    You've got issues if you were liking it Rob.. lol
    Quote Originally Posted by Hybrid
    Issues is an understatement. It's given me the shits already and i've only just started, Ive already got cuts all over my hands!
    Hopefully ill get something done tomorrow. 40 degree heat in a shed removing turbo's, super fun happy times!
  1. CT12A rear turbo Y pipe removal
    By richzx in forum Tech and Conversions
    Last Post: 20-08-2007, 07:58 AM
  2. JZZ30 Loom Vs JZA70 Loom
    Last Post: 12-04-2007, 04:33 PM
