Results 16 to 22 of 22
Thread: Intake pipe diameter
    Junior Member Backyard Mechanic Wedged'86's Avatar
    Jun 2006
    Default Re: Intake pipe diameter
    Thanks for the help so far guys... but i think i'll just ask a guy at work rather than risk getting called immature and my defensive posts edited.
    Thanks again.
    nah, they were edited cos i was being an arse and your sig was teh ghey
    On my bigport i had a 2.5" to 3" joiner on the tb (2.5" joiner fits the O.D of the 4age throttle body perfectly). I ran 3" pipe off that (I had some lying around). I fitted my 3" k&n pod straight onto that.
    I'm pretty sure the 4AGE 100kW throttle body is 54mm ID but I'm going off memory which isn't always good.
    Chiba
    Quote Originally Posted by Aust162
    I'll be doing the same on my GZE with 4AGE TB. Except I've got me an Apex'i filter instead.
    who would have thought that if you did a search......
    on google...
    with the search terms "4AG intake pipe diameter"...
    the first page on the list gives you the diameter....
    http://www.google.com.au/search?hl=e...e+Search&meta=
    http://jared.catspyjamasdesign.com/throttlebody.html
    in fact.. the first two sentences read like this..
    As you may be aware, one of the most restrictive sections of the 4AGZE intake is the throttlebody. At only 50mm in diameter, it is quite smaller than 4AGE throttlebody's 55mm diameter
    searching just requires the use of google, and some search terms.. sometimes you need to vary the terms... like.. 4A, 4AG, 4AGE.. or intake pipe, intake tube.. or size, diameter..
    but usually, somewhere will have the information you need.
    not trying to pick, but if i can find that in 5 seconds.. you should be able to find it at least within 5 minutes... all i did was search for the title of the thread
    Chiba
    ^^^ That's my site! So you can be assured it's correct... (I measured with vernier calipers.)
  1. JZA70 and MA70 Specifications
    By twentyEight in forum Tech and Conversions
    Last Post: 18-12-2016, 10:18 AM
  2. T, 2T, 2T-B, 2T-C & 2T-G Specifications & Diagrams
  3. Replies: 9
    Last Post: 12-04-2008, 05:59 PM
  4. 1UZFE AFM and stock 7MGTE intake pipe (also SAFC question)
    By doobs in forum Tech and Conversions
    Last Post: 11-05-2006, 05:32 PM
