Results 1 to 15 of 24
Thread: 7M/1J starter motors
    Western Aus
    Default 7M/1J starter motors
    from memory, 7M auto and 7M manual starter motors are exactly the same.
    i also recall 7M auto and 1J auto starter motors being really, really similar (but not 100%)
    and i recall 1J Auto and Manual starter motors being same same.
    so, heres my question:
    i have a mate with a manual Jzz30 with a fucked starter motor, and i happen to have a 7M starter in the cupboard.
    he needs the car off the road for the shortest amount of time possible (roll starting FTW ATM) so i cant really take the old one out to compare, and we havent had the luxury of finding a 1J one for sale... so who knows how long it'd be off the road for if it isnt same.
    help please? my + rep button will have sex with your rep count.
    Default Re: 7M/1J starter motors
    JZ Auto and Manual are definately the same, as the starter bolts through the backplate of the block anyway.
    From what i have read on ToyotaCressida forums 7M US starters are the same as JZ US starters, which means i would assume that it is the same the world over....
    What may vary is the % of reduction etc, but i doubt that would change too much.
    Western Aus
    as long as it starts the car, im happy.
    i know the auto/manual are the same because everyones doing manual conversions without touching the starters, and i recall 1J and 7M being stupidly similar!
    but id need someone that can confirm 100% before i start taking anything apart.
    thanks takai, legend as always!
    I've placed a 5m starter (same as 7m really) on a 1jz block, it looked to fit fine
    I suspect they fit a treat...try it take pics and tell us for sure.
    Western Aus
    ahhaha
    ok, sounds good enough to give it a shot, ill be your test mule
    will go today/tomorrow and let yas know.
    AFAIK 7M and 1J manual use the same clutch kit, which means same diameter flywheel, which would hopefully mean the ring gear is the same (if thats the correct term for where the starter contacts the flywheel?)
    AFAIK the only different between 7M and 1J manual flywheels is the bolt number/spacing in the centre for the crank.
    yeah, ring gear is the same
    wa
    have you tried repairing the starter motor
    most of the time it will just be the contacts which are available from an auto sparky for about 20 dollars and take about 10 mins to fit once the starter is out
    Western Aus
    well initially it was the contacts, until he overheated the motor and a massive plume of smoke came out from under the CLOSED bonnet :|
    crazy...
    but 7M looks like it bolts from the front of the motor, while the 1J bolts from the gearbox side, so fuck knows how that works?!?!?!
    How does that work? My 1J starter bolts from the engine side, just replaced it 2 weeks ago. Looked similar to a 7M item and interestingly nothing like a 2J starter
    7M has a bolt and nut configuration from memory, 1JZ has the thread in the starter motor...from memory!
    Dont some of the older M starters have threaded holes too?
    User Conversion King
    NWA
    this is usually the case where schwarzenegger has tightened up the bolts and consequently stripped the thread in the starter. easy fix ofcourse is to put a nut on the outside
    hello
    No, he's right, 7M starters dont have threaded holes but I have an old M series starter here that does, 5M I think I got it from (not that that means that's where it originated)
    Western Aus
    both my JZA70 and this JZZ30 bolt from the gearbox side, and thread into the starter casing.
    the 7M however, has no thread in the mounting holes on the casing, leading me to believe (along with the marks made by bolt pressure on the opposite side of the casing) that the bellhousing is threaded on the 7M, (MA70 GT limited 1990 Auto).
    so ill wait till i pull out the motor and compare them, physically, they're a completely different size, but the main part of the starter still looks compatible.
    trying again tomorrow, will keep ya posted.
    oh, and Schwarzenegger did do up the bolts, i had a spanner hanging off the 14mm spanner on the bolt, all my weight on it, and it didnt budge...
    might try some penetrating (ehhehehehe) oil and give it another shot, might even start the motor to warm it up, at the risk of burning the fuck out of my hand on a hot motor..
    I'm pretty sure Ed posted this in the "Toyota's Interchangable Oddities" thread. It's somewhere in the ~10 pages!
  1. 4AGE reduction starter clarified
    Last Post: 28-11-2011, 08:09 PM
  2. starter motors
    By rollin in forum Tech and Conversions
    Last Post: 16-11-2006, 06:28 AM
  3. wat starter motors fit a 3tgte??
    By lilcrash in forum Tech and Conversions
    Last Post: 20-02-2006, 06:43 PM
  4. 3K starter pinion center distance from crank center?
    By 510rob in forum Tech and Conversions
    Last Post: 14-01-2006, 08:34 PM
