Results 1 to 14 of 14
Thread: Header design help required
    Default Header design help required
    I have ordered set of Supra NA headers for my 7MGE Cressida and I know I will need to replace the rear section. The basic design is the 6-2-1 and the whole thing comes apart in the middle section where there are only 2 pipes. I plan to have a new section made that includes the 2 pipe section, the Y pipe and then all the way to the Cat.
    Question is how long should I make the 2 pipe section before it rejoins in a Y section?
    I want to tune it for a torque peak around 3500rpm.
    This is what they look like.
    Penrith BC
    Default Re: Header design help required
    the two pipe section should be about as long as the primary pipes, or a multiple therof
    ed
    ../delete/ban
    tech moderator
    Quote Originally Posted by ed_jza80
    ed
    Thanks Ed
    Do you know of any online calcs or anything like that?
    Penrith BC
    ../delete/ban
    tech moderator
    worships the 2JZ (GE lol) 1st year Apprentice uncivilised's Avatar
    Are these the obx headers usually advertised on ebay us? Hope they dont foul the steering shaft. If i stay with my 7M for a bit i might do this as well.
    Quote Originally Posted by uncivilised
    Yes they are. I will let you know how well they fit.
    Junior Member Backyard Mechanic 1jzracing's Avatar
    the critical length is the total from the valve to the last collector, so for torque in the lower range like you want go for about 35 to 36 inches. remember this is from the VALVE not the head face right past the midle collector to the start of the Y you are adding
    by comparison an engine with peak power at 8000 the length would be about 31 to 32 inches
    a fool remains undescovered untill he speaks!
    hey andrew,
    didnt you get some liverpool headers?
    have you got a link to these obx suckers?
    cheers, blake
    hey andrew,
    cheers, blake
    I had a second hand set of hurricane headers and sold them to slowcressy on the cressida forum. He has since fitted them up and seems to be happy.
    I wanted mandrel bent stainless headers and these appear to fit the bill.
    BTW I may need your help in fitting them up.
    Here is the link. Ask for Alex and he charged me $120 US for shipping. Our dollar is so high ATM I couldn't rseist. I also had some Paypal credit to use.
    http://cgi.ebay.com/ebaymotors/OBX-R...spagenameZWD2V
    Penrith BC
    Quote Originally Posted by 1jzracing
    disagree... first collector. thats where your primary wave boundary is coming from
    ../delete/ban
    tech moderator
    Headers arrived today. On first inspection they look good.
    I will post up some pics shortly.
    sir Grease Monkey
    tasmania
    old speedway trick . cut the 2 into 1 collector off , fit the pipes to the engine , warm the engine up and run it up to a constant 3000rpm untill the pipes warm up then with a spraycan squirt a line of paint down the secondary,s and where the paint stops burning off , put your collector there. i,m sure i,ll get a bagging for this but if it was good enough for the likes of dave bennett ,phil irving, the crumps etc theres got to be something in it. cheers bigwad
    You'd want to hold the engine at the revs you want to tune the extractors to..
    Penrith BC
    Quote Originally Posted by big wad
    thats called a harmonic antinode
    and ben is correct
    +rep... i like the idea
    ../delete/ban
    tech moderator
  1. Information on 4-2-1 header design
    By nick.parker in forum Tech and Conversions
    Last Post: 19-11-2006, 10:45 PM
  2. 20v headers design
    By vtrfirestorm in forum Tech and Conversions
    Last Post: 16-11-2006, 07:29 PM
  3. 20v header vs starter
    By DeftAnesthetik in forum Tech and Conversions
    Last Post: 07-07-2006, 10:10 AM
  4. External radiator header tank
    Last Post: 12-10-2005, 11:52 AM
