seek and you will find
http://www.toymods.net/forums/showthread.php?t=28672
Hey all
Was working on my ae86 the other day and put the keys down.. now i can't find them anymore and i only had one key! garghhh
Does anyone know if any of the ignition barrels/locks are swappable from other toyotas/cars?
i have never seen a ae86 at a wreckers.. so i'm wondering if i can take it out of anythign else?!
Thanks!
"He who speaks doesn't know, he who knows doesn't speak..."
get a locksmith out to remove it or take the column to a locksmith and get them to remove it and rekey it.
probly cost $50 if you take it to them, while your there ask for a spare.
linden
Originally Posted by WHITCHY
If you take out the drivers doors' lock barrel you'll find a 6digit or so code on it, just give this, or just give the barrel to the locksmith and they will make up a key for you in about 5-10mins!
and a hell of a lot easier than removing the ignition lock.
hehe.. i posted this in a few other forums and you have all said the same thing! lucky i asked! i was freaking out and thought i was doomed! thanks all! i had no idea that i could get a new key cut!
THANKS!
Plus, most of them are so worn that any Toyota that uses the same size key will pretty much fit...
that is if the drivers door and ignition barrel use the same key, out of 16 ae86's ive worked on this has only been the case on 2.Originally Posted by Devils
linden
hrmm.. if the key i use to open the doors and boot, also starts the car.. am i right in saying that it would be he same key for the ignition too?Originally Posted by The Real Roadrunner
yep..............
Ahh...So true! One set of keys works for both of my corollas (ae82 & ae86), and that has gotten me out of trouble before.Originally Posted by mrshin
AE86 4 shades of silver - The Lone Ranger's steed is on the road again!
AE86 shell - waiting for a donor car from the auctions.
What devils said is the way to go for a new key for your toyota even if you have the original worn key. The locksmith will make one to the new specification and you will not have a copy of a worn key.
Jealousy is a curse
too many choonga's for u, lay off them and you'll remember things betta![]()
try using the dipstick to start the car... works on ea's![]()
Originally Posted by cuzzo
Originally Posted by Bananaman
Is that oil type dipsticks or just falcon drivers in general?![]()
Vanman
