Results 1 to 10 of 10
Thread: air con in to the ra23
    Apr 2007
    queensland
    Default air con in to the ra23
    ok i just after some help with the old putting aircon in to the ra23, i have a ra40 aircon setup, and my ra23 was previously aircon. that means all the wiring is there, will the plug out of the ra40 aircon box hook to the ra23 plug. a thread with a guide would really help.
    Default Re: air con in to the ra23
    Someone has to have done it first to write a guide, and you may be the first.
    ... so write a guide for the rest of us when you have worked it out
    chekc the wiring diagrams for both. and the pins on the"devices"... it may be that simple.. but it may not...
    have a look see in the manuals for both cars?
    Apr 2007
    queensland
    i am not the first to do this, heaps of people have done it, thats why they sell ra40 aircon stuff as a ra23 kit
    If you're anywhere near Brisbane you can check out my factory aircon setup to see how it all works. I've been meaning to pull it all out anyway.
    Theoretically the wiring should be the same. If the plug isn't the wire colours probably are.
    Getting under there with the unit and checking the plug would be the first step and then back it up with wiring diagrams.
    Simon
    Beige.... The new Black!!!
    Simon, was my RA28 originally AC?? Or was that just something you threw into the bargain?? Anyways, if I find some time this arvo Ill have a check of my RA2x AC box, and the two RA40 AC boxes I have in the shed. Should be able to get a bit of an idea from that.
    No it wasn't, It was however missing the cross pipe (or more correctly it was broken beyond reasonable repair.) I did find one but it never got in. I was planning A/C by summer so I the A/C box went in to get the heater operating to the vents properly. (iirc I needed to find a clip to secure it properly to the blower unit.)
    Simon
    Yeah, I got the clip... seems to be the same as the early RA40, but the facelift RA40 had a solid piece there.
    As a note, I intended checking the two boxes for you, but took the work car home last night and left the RA28 in the work compound. Will try and do it tonight
    Apr 2007
    queensland
    nah i am gathering my information, atm this weekend i am going to rip my aircon box out my ra23 cause someone cut the pipes off, for both the aircon box and the heater box, so i am going to see if i can get a new core for the heater box and use the ra40 aircon box. i am going to start works this week end
  1. RA23 vs 2JZ-GTE Part 2 (Now with Pics)
    By bugeyedcreepy in forum Engine & Driveline Conversions
    Last Post: 05-08-2007, 09:15 PM
  2. 2T into RA23 (temporary while I rebuild 18rgu
    By floppy in forum Tech and Conversions
    Last Post: 29-01-2007, 12:37 AM
  3. TA23 vs. RA23
    By 'ol_skool_'75 in forum Tech and Conversions
    Last Post: 29-10-2006, 07:23 PM
  4. Replies: 24
    Last Post: 18-04-2006, 01:42 PM
