Results 16 to 20 of 20
Thread: quick q's...are RA23 and TA23 front struts the same?
    Default Re: quick q's...are RA23 and TA23 front struts the same?
    I don't think TA22 and TA23 suspension would be the same.
    For starters they run different spacing on the strut towers.
    The lower control arms are also different.
    The TA23 might run the same spring rate as a TA22 due to the engine being the same weight as a TA22.
    TA23 and RA23 strut lengths would be the same.
    So TA22 and TA23 would not be inter-changeable.
    south austraila
    But what about the angle of "camber"...???
    But with my lack of .... i would say that the struts are the same, with some small differances.. eg. spring cup, ..
    The brakeing system on the TA's is only standard "celica" spec....
    The RA's got a "GT" spec brakeing system.. eg. larger, with front to rear ( byest. ) bias..
    The RA's strut's/brake's should fit, a "TA", BUT you would also need the front to rear ( byest. ) bias for "GT" brake's...
    My '82 GA61 XX only had the small, "Celica" brake's, on it from factory, "No front to rear" like the RA23/28/40's,MA61's...
    In shot our RA23's to RA65's all got the "GT" spec. brakes...
    TA22/23 got only crap....
    Project: '82, GA61 XX
    Quote Originally Posted by GA61XX
    The RA's got a "GT" spec brakeing system.. eg. larger, with front to rear bias...
    The RA's strut's/brake's should fit, a "TA", BUT you would also need the front to rear bias for "GT" brake's...
    Is that what you meant?
    ([][][]II--LT--II[][][])
    Junior Member Grease Monkey 9000rpm's Avatar
    Tasmania
    I've just had a look at part number on the old microfiche of a front strut leg/tube thing....
    12/70-4/74 TA22 48021-14021
    4/74-9/75 TA22, TA23 48021-14022
    10/75-7/77 TA22, TA23 48021-14013
    10/75-7/77 RA23, RA28 48021-14030
    8/77-7/81 RA40 48021-14050
    It might help.
    south austraila
    Quote Originally Posted by twentyEight
    eg. larger, with front to rear bias...Is that what you meant?
    Cool.. thanx'... Pass'ed Tec. & Failed english...
  1. TA23 vs. RA23
    By 'ol_skool_'75 in forum Tech and Conversions
    Last Post: 29-10-2006, 07:23 PM
  2. 1g-gte front winged sump into TA23 Sway Bar issues!
    By hemi twofifteen turbo in forum Tech and Conversions
    Last Post: 22-09-2006, 09:27 AM
  3. 1g-gte front winged sump into TA23 Sway Bar issues!
    Last Post: 21-09-2006, 10:08 PM
